| | | Forums66 Topics128,087 Posts1,055,976 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2009 Posts: 235 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 235 | 1956 235 from a bel air
Anyone know the lengths of the bolts? I need to buy new ones. I'm pretty sure 2 are longer and 4 are shorter? Thanks
'53 Chevy 3604 Five Window Cab ('56 235)
| | | | | Joined: Feb 2004 Posts: 29,782 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,782 | Don't those engines use studs to mount the manifolds, not bolts?
| | | | | Joined: Jun 2009 Posts: 235 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 235 | Mine has a stud on each end, 6 clamps/bolts in between. I'm wanting the bolt length if someone knows.
| | | | | Joined: Dec 2017 Posts: 1,652 'Bolter | | 'Bolter Joined: Dec 2017 Posts: 1,652 | The short bolts measure 1 5/16 as measured from under the head of the bolt, so 1 1/4 length under the head may work if you can’t find the 1 5/16. The long bolts measure 2 13/16 under the head so 2 3/4 should work. Remember the head has a dowel on each end to locate the assembly.
The two long bolts get the two short clamps, the shorter bolts get the longer clamps.
Mike
| | | | | Joined: Jun 2009 Posts: 235 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 235 | Thank you so much. I tried with some odds and ends last night but none seemed right. I'll get these and try again.
