0 members (), 54 guests, and 3 robots.
Topics128,072
Posts1,055,906
Members48,429
#1259278 03/19/2018 9:50 PM
1956 235 from a bel air
Anyone know the lengths of the bolts? I need to buy new ones. I'm pretty sure 2 are longer and 4 are shorter? Thanks
'53 Chevy 3604 Five Window Cab ('56 235)
H Online: Content
Don't those engines use studs to mount the manifolds, not bolts?
Originally, they were bolts on Chevrolet stovebolt engines (sorry, I do not know the lengths).
Studs and bolts could be used.
An unthreaded "pin/stud" was at each end of the head on Chevrolet sixes.
Contemporary GMCs used threaded bolts at the ends.
https://www.chevsofthe40s.com/detail/33603/Chevrolet_Intake_Exhaust_Manifold_Bolt_Kit.html
https://www.chevsofthe40s.com/detai...aust_Manifold_Clamps_Spreaders_Cast.html
Mine has a stud on each end, 6 clamps/bolts in between. I'm wanting the bolt length if someone knows.
The short bolts measure 1 5/16 as measured from under the head of the bolt, so 1 1/4 length under the head may work if you can’t find the 1 5/16. The long bolts measure 2 13/16 under the head so 2 3/4 should work. Remember the head has a dowel on each end to locate the assembly.
The two long bolts get the two short clamps, the shorter bolts get the longer clamps.
Mike
Thank you so much. I tried with some odds and ends last night but none seemed right. I'll get these and try again.
' Offline
The cylinder head has a dowel on each end for the exhaust manifold .
https://s26.postimg.org/8rfi9n389/Studs.jpg
George
'54 3600
1954 3600
Now cruising in
The Passing Lane
