1 members (klhansen), 107 guests, and 1 robot.
Topics128,062
Posts1,055,856
Members48,428
#1257938 03/08/2018 10:53 PM
Anyone know if you can do a direct swap from the SM420 to a NV4500 in a 65 Chevy bell housing with a 292 inline 6?
1955.1 Chevy 3600 NAPCO Truck
1957 Chevy 6400 US FOREST SERVICE
Here's a long list of all my STUFF!
Beast57 #1257942 03/08/2018 11:30 PM
Short answer is no, it’s not a direct swap. Adapters are available.🛠 This info based on our own Search function and a search for NV4500. Try a search, you might just find the exact info you need.
Beast57 #1257972 03/09/2018 6:15 AM
I think that advance adaptors can supply what ever that you need to do the job
ron
Beast57 #1257993 03/09/2018 2:51 PM
It looks like the 93-95 GM transmissions are the ideal candidates, still using the early Muncie style front pattern. I'm assuming they are like finding unicorns by now. Not to mention seems like ALOT were 4wd.
Here's some good info on adapting the NV4500.
NV4500 to Jeep
NV4500 to Dodge
Looks like Advance Adapters sells kits for doing swaps.
Info
Kits
If you have a later model trans, it may be possible to just have the lower holes drilled in the NV4500 case and have your bellhousing center hole opened up.
1954 3600 Chevy Truck
"The Fake Truck"
More pix on Photobucket
Beast57 #1258053 03/09/2018 11:39 PM
COOL THANKS SO MUCH!
Beast57 #1259147 03/18/2018 9:51 PM
You can put an n4500 up to a 292 with a little machine work. No adapters are required. However it needs to be a 92-95 one. It's pretty easy.
Beast57 #1259225 03/19/2018 4:26 PM
Perfect! Thanks for that info. I will go dig up one of those 92-95 NV4500s wave
What mods/machine work would i have to do?
Beast57 #1259237 03/19/2018 5:49 PM
Here is a little secret. It's assumed these where only in the 3/4 and one ton trucks. But 93-95. 1/2 ton." WT" 4x2 trucks . Those special option Cheyenne trucks. Got the nv4500 if it came with a 5 speed. They even put them behind the little 4.3 v6. That's my favorite way to find them. Those work truck optioned rigs are easy to find and they don't cost much money generally. I always find them sitting at landscapers and contractors back lots.
Beast57 #1259264 03/19/2018 8:50 PM
I like secrets! Thats great to know!
Beast57 #1259267 03/19/2018 9:01 PM
If you find a 68-72 Chevy pick up manual bell housing that removes one step. And allows you to still keep your cradle mount on the bell housing. If you use your earlier bell you need to have the center bore opened up to the 5.120 size of the early nv4500. Then you drill and tap the front to 1/2 x20 on the front of the trans for the muncie pattern. Add the pivot stud to the retainer on the trans. And bolt the bell to the trans. Uses all the stock clutch and pilot bearing. You need to cut a new hole in the floor for the shift tower.
Beast57 #1259268 03/19/2018 9:11 PM
I am going to send a pm. I like this site. But pictures are worth a 1000 words.
Beast57 #1259271 03/19/2018 9:22 PM
what i have going on is i have a 1954 Chevy 3100. i have put a 292 in it with the 1965 bell housing that bolts to my original cross member. i have bolted my original 54 sm420 trans to it. all this is installed and working in my truck and i drive it. i will have to do the mod to my bell housing since its already in there.
Beast57 #1259274 03/19/2018 9:27 PM
couldnt i just use the fork thats already on my 65 bell housing?
Beast57 #1263712 04/25/2018 10:40 PM
http://67-72chevytrucks.com/vboard/showthread.php?p=6488778&posted=1#post6488778
Check out that thread. That's how I did mine. Used the stock bellhousing and stock clutch linkage. If you don't mind changing out your transmission crossmember (I did mind, hence the adapter plate), the stock chevy bellhousings for any of the nv4500 transmissions will bolt up to the later i6's, sbc, bbc, and w motors. You just end up having a transmission mount at the rear of the trans instead of under the bellhousing
Liquidated my projects
Now looking for a decent '47-'55.1 3100, 3600, or 3800
