4 members (gswbbc, 32Fordpuchoptop, dwreills, Otto Skorzeny), 77 guests, and 2 robots.
Topics128,035
Posts1,055,447
Members48,422
#1257829 03/07/2018 9:48 PM
Can anyone tell me where I can find info on towing weight limits for 1967 model c10.
blue67fleetside #1257832 03/07/2018 10:38 PM
This question draws a lot of arguments. Are you referring to a bone stock I-6 or a bone stock V8? Modifications? Google will bring up lots of differing opinions.🤷🏼‍♂️
blue67fleetside #1257836 03/07/2018 10:51 PM
62401
Around this hobby, it seems to me that the top five things that get people into the most trouble fastest are brakes, tires, steering, brakes smile and ... trailers/towing. And did I mention brakes??
Couple suggestions...
1. Read Barry Weeks' excellent article on trailering -- it will help you figure out what you actually need to do here.
2. Try asking this same question in the Hauling Forum -- There are folks who prowl that forum who know quite a lot about this.
Good luck with whatever it is you are trying to move!
And check your brakes.
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
blue67fleetside #1257855 03/08/2018 1:14 AM
Ditto on brakes. Most of these trucks, even the ones with the anemic 6 cylinders, are capable of getting a lot more weight moving than they can stop effectively. If you're pulling anything more than a small single-axle utility trailer with a very light load on it, you probably need brakes on the trailer. Nothing increases the pucker factor like getting pushed across a busy intersection by a trailer that JUST- - - - -WON'T- - - - -STOP!!!!!!!!
blue67fleetside #1257859 03/08/2018 1:27 AM
It is a unrestored c10 with a 250 in-line 6 & 3 speed column shift with non synchro 1st. My plan is to change the front brakes over to disk sometime soon. My wife and I have been playing with the idea of buying an older camper to restore to pull behind it and our newer vehicle. I have pulled trailers with and without brakes and having them on the trailer are definitely in the plans.
blue67fleetside #1257862 03/08/2018 1:44 AM
Having survived some pretty hairy driving emergencies while pulling a trailer, let me offer a suggestion- - - - -if you can figure out a way to mount your trailer brake controller in a position where you can manipulate the manual control with your knee, it lets you keep both hands on the wheel when reacting to an emergency. I usually fabricate a small extension to the manual button and mount the controller to the dash or steering column near my left knee. It's saved my bacon a couple of times!
blue67fleetside #1257928 03/08/2018 7:53 PM
I agree that trailer brakes are a must. you can get hydraulic brakes controlled by a master cylinder in the tongue and are self adjusting.
my truck has a built in electric controller that you set the gain and requires no other action when driving. I'm guessing this could be added to your truck.
blue67fleetside #1257929 03/08/2018 8:02 PM
Requirements vary by state, but it's generally anything over 3.000 lb rating for the trailer requires trailer brakes. Some states its a lower number.
1952 Chevrolet 3800 pickup
---All pictures---
blue67fleetside #1258396 03/12/2018 4:33 PM
Here's what happened to me.
I have the 64' with an 87' front and rear installed. Went back to Kansas recently and rented a Uhaul car trailer to bring home my 38', minus an engine and tranny. Have a 98' Vortec engine and a 91' T_5. (Yeah, I know, sounds like something Johnny Cash talks about).
It did the job well enough, and actually handled well enough, but kept me honest and paying attention.
Got on top of Monteagle, after dealing with the idiots going up the mountain and pulled into the truck pullout before going off the mountain, and found the brake pedal with Way Too Much travel. You'll understand what pucker factor is all about in that case. I finally got down and made it through Chattanooga without killing anybody.The trailer had brakes, mounted on the tongue, and the truck had plenty of shocks and the hitch for the job, but I'll never hook up to anything that heavy again. After 20 years running around the country as an owner operator, and over a million miles under my butt, I can't remember ever being so stressed pulling a load.
I'm looking forward to buying a motor coach and sitting in back and letting Ma chauffeur me around for a change.
Last edited by Justhorsenround; 03/12/2018 5:08 PM. Reason: Inappropriate language.
dj durant
More pix on Flickr
blue67fleetside #1258745 03/15/2018 6:06 PM
My usual response is a much like the others said, but I always ask, how much can you stop?
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
blue67fleetside #1258784 03/15/2018 11:27 PM
For anyone pulling a trailer with an old car, and just plain entertaining, "The Long, Long Trailer" with Lucille Ball is a must see movie. A 30+ foot camper behind a 53 Merc convertible. It's all about trailer brakes, and actually very educational.
blue67fleetside #1259222 03/19/2018 4:16 PM
Sounds like towing with it should probably be rethought.
