Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
4 members (Greg_H, GMCJammer51, 3B, Jay R), 152 guests, and 4 robots.
Topics128,274
Posts1,058,435
Members48,490
#125902 05/01/2007 12:16 PM
what causes single stage paint to orange peel?
#125903 05/01/2007 1:07 PM
just the nature of the beast .....it dries so fast it doesnt flow-out , an ya get orange peel
1952 Chevy Shortbed
Photos in Photobucket
#125904 05/01/2007 1:10 PM
thank you, i won't put it in the sun right away this time,,,
#125905 05/01/2007 4:02 PM
Actually orange peel comes from the way that the material is applied,not the material make up or type of paint.granted some spray better than others but lets get to the point.usally peel is achieved from being to far away from the panel or to high of air presure ,or a little of both.if it is drying to fast try a slower reducer and hardner this will give you a longer window and it will flow out some more for a smoother look. smile
Bent Happy Haulin!
TWO 1963 GMC\'s -- A shortbox and a NAPCO!
#125906 05/02/2007 8:50 AM
Bent got it- base/clear can do it too.
Paint & Body Shop moderator
#125907 05/02/2007 11:54 PM
Reducing the material incorrectly is probably
the error most make that have that problem.
Bill B.
1952 Chevy 3104 Shortbed 5-window
Remember; Politicians and diapers both need to be changed
often, and for the same reason.....
#125908 05/03/2007 8:41 AM
not mixed right or to cold or wrong air pressure the smother you can get that paint to lay down the better sometimes its how thick your applying it watch what its doing as you laying it down
#125909 05/06/2007 7:36 PM
It's also why two stage is so popular. The color coat is relatively easy to apply. Multiple coats of clear can then be color sanded flat and polished up to a high shine. Single stage paints must be applied just so and when done correctly, look terrific. Knowing how to push on alot of paint and not have it sag is a skill that requires alot of practice. Air pressure, gun adjustment, distance from the work, keeping the gun at 90 degrees to the surface and speed you make your pass all go into the equation. I've seen skilled painters put on a coat, leave the booth for a few, come back, put on another coat, leave the booth, come back in half an hour a see the paint has flowed out beautifully.
#125910 05/09/2007 6:19 AM
Actually orange peel is caused by an inaccurate fluid adjustment. Too high an air pressure causes runs and sags.
The best way to reduce the affects of orange peels is to increase fluid flow and adding a slower reducer. More paint flows better than too little paint. A slower evaporating reducer allows the paint to flow before becoming too thick by the evaporations of the reducer.
Even the clear coat of a bc/cc system will orange peel if the gun adjustments aren't correct. It's just easier to sand out the imperfections, then buff and polish than it is with a single stage paint.
No better smell than that of fresh paint. I've been building and painting cars/trucks for 47 years. Not gonna stop now.
http://www.coxcustomcars.com/
