0 members (), 69 guests, and 0 robots.
Topics128,115
Posts1,056,292
Members48,439
I’m trying to bring the bed sides vertical to my tail gate. They are angled out at the top about an inch on both sides. What can I do to bring these in closer to the tail gate?
Thx Don
Can’t begin to tell you how much I hate the name Stovebolt.
Loosen the 4 bolts on the bottom of the rear stake pocket, realign the bed side, and then re-tighten. Then do the other side. That should do it, hopefully, without having to loosen things further forward.
Kent
1937 Chevy 1/2 ton
1942 Chevy 1/2 ton
1947 Diamond T Model 509
1951 Chevy 1/2 ton
Thanks Kent
that should work - i did it on mine. you can put a ratchet strap across the rear stake pockets to pull the sides together if need be. open or remove the tailgate to give room to over-pull a bit. they will spring back into the desired position.
After loosening the bolts you can use a paint stir for a guage and bolt thru the chain hook hole to maintain desired gap. Have fun and good luck
Dan
Well this proved to be quite easy and now I have straight sides. Had a warped tailgate and corrected that too. Thanks for the advise. BTW I also only had 2 bolts on each side so now it should remain that way after adding the bolts.
I’ve been on vacation all week so I’m knocking off my to do list.
Thx Don
