0 members (), 155 guests, and 4 robots.
Topics128,110
Posts1,056,241
Members48,437
#1257522 03/05/2018 9:24 PM
Hi Y'all, Several years ago someone posted a link to a socket to be used on the Pinion Nut of a 3/4 ton differential. Maybe you could post it again I swear I bought one. Yet my stock of tools has increased over the years and I cannot find it
Julian Carter
1970 Triumph GT6
1967 Triumph TR4A
1952 Chevy 3600
1948 MG-TC
Pinion yoke holder tool, to help remove or torque pinion nut http://www.ratechmfg.com/Yoke%20tools.htm
The nut takes a regular socket, nothing special. (I don't recall size)
•1952 Chevrolet 3800 pickup
---All pictures---
Thanks Grigg, I'm holding it with a chain wrench. I purchased a 42mm socket but ended up with a impact socket that was way to thick to grab hold.
Julian Carter
1970 Triumph GT6
1967 Triumph TR4A
1952 Chevy 3600
1948 MG-TC
Julian,
I used a 3/4 drive , 1- 5/8 " socket, had the OD turned down to 2.140" for a length of .850" from the end of the socket on a friends lathe in order to get it to fit into the allowed clearance. Used 1/2' drive impact with adapter to remove the nut, Used a pipe wrench on the "yoke" rotated to wedge against the floor to prevent it from turning . Worked like a charm !
Ron - - Dusty53
1954 Chevy 3604
With a high quality air impact .......the nut is likely spin right off with no need to hold the yoke.
OK, So I purchased the Ratech item found here : http://www.ratechmfg.com/Yoke%20tools.htm
The item I bought is the second one on that page. I'm trying to figure out how it used specifically the center piece that somehow attaches to the pinion nut???
Julian Carter
1970 Triumph GT6
1967 Triumph TR4A
1952 Chevy 3600
1948 MG-TC
Use bolts in the slots and in the ears of the yoke as shown.
The center part is just a jacking screw to then remove the yoke from the shaft if necessary.
You'll use a breaker bar, ratchet, or torque wrench as necessary with a correctly fitting socket.
Second breaker bar on the holder tool to keep it and the pinion from turning.
---All pictures---
Thanks Grigg
Julian Carter
1970 Triumph GT6
1967 Triumph TR4A
1952 Chevy 3600
1948 MG-TC
Got the Pinion nut Off. I finally purchased a plated socket 1 5/8" and tapped it on. It worked well. Took the impact socket to a machine shop. They said it was to hard to turn????????????????
Julian Carter
1970 Triumph GT6
1967 Triumph TR4A
1952 Chevy 3600
1948 MG-TC
