4 members (Shaffer's1950, artinva, Chip O, 1 invisible), 124 guests, and 3 robots.
Topics128,072
Posts1,055,903
Members48,429
#1258603 03/14/2018 1:25 PM
2 questions please...
1.) A or B ? (see photos)
2.) How many turns before hooking it?
Thanks, Jim
Gravity and the counterweight should assist the flap opening as the spring heats up. Turn the spring far enough for the flap to barely close when the engine is cold. If you want to check the operation, heat the spring gently with a Propane torch- - - - -the counterweight should cause the flap to move to the "heat off the intake" position. That's also assisted by exhaust gas velocity at cruise RPM.
B is correct.
About 1/2 turn.
Shop manual - heat riser
1/2 turn is on the previous page in the above shop manual link.
-Tom
1950 Chevy 3100 w/ 1956 235
