1 members (baldeagle), 89 guests, and 4 robots.
Topics128,037
Posts1,055,466
Members48,424
#1258014 03/09/2018 4:11 PM
i have a 52 chevy 3800 1ton truck. my question is can i put a plow on it, and if so what kind
jimbo 24 #1258018 03/09/2018 4:30 PM
A plow to push like for snow, or one to pull like for the garden?
I'm sure you could do either, but traction is probably an issue in any case. You might need chains and a good amount of weight in the bed.
My 1 ton spins or gets stuck real easy in snow, and wet grass just the same, normal tires.
Would another vehicle or tractor be better suited to a plow?
1952 Chevrolet 3800 pickup
---All pictures---
jimbo 24 #1258024 03/09/2018 5:01 PM
We have a couple of members who do snow removal but they don’t use antique trucks. Maybe they can point you towards a particular product. I’m fairly certain you will have to have some major fabricating skills. Good luck.🛠
Justhorsenround #1258715 03/15/2018 2:47 PM
thanks guys. it was just a thought. maybe just a snow blower.
jimbo 24 #1258794 03/16/2018 12:34 AM
Crusing in the Passing Lane
One can easily convert to a 4wd truck, which would easily operate a snow plow.
Ed
jimbo 24 #1258831 03/16/2018 12:39 PM
It's not real easy to make an AD 1 ton into 4x4, they are so narrow most driven front axles with 8 lugs are newer and therefore wider, and the ones that are narrow enough, like from perhaps a jeep are not really strong enough.
There were aftermarket 4x4 conversions back then, Coleman I've seen one of, and a couple NAPCO. They would be difficult to find, possibly expensive.
---All pictures---
jimbo 24 #1259176 03/19/2018 2:21 AM
GMC made some wide front fenders for '41-'47.1 that allow a full width, modern, 4wd front axle to be fitted without tire stickout. I have 2 sets.
Ed
Moderated by  Dusty53
