| | | Forums66 Topics128,036 Posts1,055,450 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2013 Posts: 363 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 363 | i have a 52 chevy 3800 1ton truck. my question is can i put a plow on it, and if so what kind | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | A plow to push like for snow, or one to pull like for the garden?
I'm sure you could do either, but traction is probably an issue in any case. You might need chains and a good amount of weight in the bed. My 1 ton spins or gets stuck real easy in snow, and wet grass just the same, normal tires.
Would another vehicle or tractor be better suited to a plow? | | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | We have a couple of members who do snow removal but they don’t use antique trucks. Maybe they can point you towards a particular product. I’m fairly certain you will have to have some major fabricating skills. Good luck.ðŸ›
| | | | | Joined: Jul 2013 Posts: 363 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 363 | thanks guys. it was just a thought. maybe just a snow blower. | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | One can easily convert to a 4wd truck, which would easily operate a snow plow.
Ed
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | It's not real easy to make an AD 1 ton into 4x4, they are so narrow most driven front axles with 8 lugs are newer and therefore wider, and the ones that are narrow enough, like from perhaps a jeep are not really strong enough.
There were aftermarket 4x4 conversions back then, Coleman I've seen one of, and a couple NAPCO. They would be difficult to find, possibly expensive. | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | GMC made some wide front fenders for '41-'47.1 that allow a full width, modern, 4wd front axle to be fitted without tire stickout. I have 2 sets.
Ed
