| | | Forums66 Topics128,119 Posts1,056,311 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2015 Posts: 149 Shop Shark | | Shop Shark Joined: Jun 2015 Posts: 149 | Finally installed the heater and Ranco Control valve back into my'48 truck. Where is the proper/functional location for the small capillary tube to go? It has a small clamp with screw/bolt hole attached to it also. Thanks Jeff | | | | | Joined: Dec 2013 Posts: 789 Former BMW Rider | | Former BMW Rider Joined: Dec 2013 Posts: 789 | Jeff, See Figure 99. Sounds like you're making good progress! | | | | | Joined: Jun 2015 Posts: 149 Shop Shark | | Shop Shark Joined: Jun 2015 Posts: 149 | Andy
"Bingo"-exactly what I have been searching for ! Finally putting back in everything I removed to install firewall and floor mat, almost finished then back to wiring!
Thank you Jeff | | | | | Joined: Mar 2010 Posts: 10,281 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,281 | The problem I had was expecting the short screw to stay put being screwed into the original, crumbly cardboard dash cover.
| | | | | Joined: Jun 2015 Posts: 149 Shop Shark | | Shop Shark Joined: Jun 2015 Posts: 149 | Brad
Excellent photo! What a massive collection you have! !
Carl,
I imagine that would be difficult, got the sensor installed today and the ABS Plastic firewall cover was great for securing the screw!
Thanks again Jeff | | |
