| | | Forums66 Topics128,048 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2010 Posts: 166 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 166 | Hi guys. Hope I'm not beating a dead horse here. Does anybody have pictures of the bracket that goes under the rear springs that holds the link of lever shocks? Mine is a 49 GMC with double action shocks. What the truck came with were two, built with the butt, plates. I bought the front shock brackets from a junkyard and they sold me the rear as well, but I don't think the rear are original. One looks like a piece of spring leaf with holes and the one that holds the link looks like cast iron with an angled shape, but hd a new hole cut with a lighter instead of a drill. I see most convert to tube shocks but I want to keep original.
Thanks for any help provided
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | What size 1949 GMC?
Many GMC 1/2-1 ton truck parts match up with Chevrolet 1/2-1 ton trucks.
Are you a member of oldGMCtrucks.com discussion boards? There are members there with documentation and GMC knowledge. Some of members here are members there. They might be able to help. Be patient - good luck.
Here, or there, post the size of the GMC.
| | | | | Joined: Mar 2014 Posts: 154 'Bolter | | 'Bolter Joined: Mar 2014 Posts: 154 | I can send you pictures from a 49 Chevy 1/2-ton, but probably not until Thursday afternoon.
I definitely have the dual-action lever shocks, which are currently removed for rebuild.
Greg Brown
| | | | | Joined: Jan 2010 Posts: 166 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 166 | I am also in the GMC site as well. Chevys and GMC were the same in that area. Mine is a 1/2 ton short bed. I will appreciate Greg the pictures. It is not a matter of life and death, just want to know what to look for or if the plates I have are correct. Have part No from the catalog but nothing appears anywhere on the net.
Thanks | | | | | Joined: Mar 2014 Posts: 154 'Bolter | | 'Bolter Joined: Mar 2014 Posts: 154 | You'll find the pictures here. Even better than just pictures, the part number is stamped on the bottom. Rear shock mount pictures
Greg Brown
| | | | | Joined: Jan 2010 Posts: 166 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 166 | Aha! Thanks. Somewhere that I can find those? Been looking for them for 4 years without any luck. | | | | | Joined: Mar 2014 Posts: 154 'Bolter | | 'Bolter Joined: Mar 2014 Posts: 154 | I'm guessing you'll have to find someone who's replacing their shocks, or entire frame/suspension. You could look in the Truck Parts for Sale forum, or post in the Truck Parts Wanted forum. Alternatively, you could try the 67-72 Trucks Forum. It's a lot more hot-rodding focused and people are regularly changing out complete suspensions. Good Luck. Greg
Greg Brown
