4 members (Otto Skorzeny, WICruiser, 55shaker, 1 invisible), 80 guests, and 6 robots.
Topics128,095
Posts1,056,072
Members48,433
#1256721 02/28/2018 3:12 AM
Hi guys. Hope I'm not beating a dead horse here. Does anybody have pictures of the bracket that goes under the rear springs that holds the link of lever shocks? Mine is a 49 GMC with double action shocks. What the truck came with were two, built with the butt, plates. I bought the front shock brackets from a junkyard and they sold me the rear as well, but I don't think the rear are original. One looks like a piece of spring leaf with holes and the one that holds the link looks like cast iron with an angled shape, but hd a new hole cut with a lighter instead of a drill. I see most convert to tube shocks but I want to keep original.
Thanks for any help provided
What size 1949 GMC?
Many GMC 1/2-1 ton truck parts match up with Chevrolet 1/2-1 ton trucks.
Are you a member of oldGMCtrucks.com discussion boards? There are members there with documentation and GMC knowledge. Some of members here are members there. They might be able to help. Be patient - good luck.
Here, or there, post the size of the GMC.
I can send you pictures from a 49 Chevy 1/2-ton, but probably not until Thursday afternoon.
I definitely have the dual-action lever shocks, which are currently removed for rebuild.
Greg Brown
I am also in the GMC site as well. Chevys and GMC were the same in that area. Mine is a 1/2 ton short bed. I will appreciate Greg the pictures. It is not a matter of life and death, just want to know what to look for or if the plates I have are correct. Have part No from the catalog but nothing appears anywhere on the net.
You'll find the pictures here. Even better than just pictures, the part number is stamped on the bottom.
Rear shock mount pictures
Greg Brown
Aha! Thanks. Somewhere that I can find those? Been looking for them for 4 years without any luck.
I'm guessing you'll have to find someone who's replacing their shocks, or entire frame/suspension. You could look in the Truck Parts for Sale forum, or post in the Truck Parts Wanted forum.
Alternatively, you could try the 67-72 Trucks Forum. It's a lot more hot-rodding focused and people are regularly changing out complete suspensions.
Good Luck.
Greg
Greg Brown
