4 members (66flea, Jon G, dt235sd, 1 invisible),
90
Mod | | | Forums66 Topics128,064 Posts1,055,860 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2012 Posts: 142 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 142 | On a 56 column shift how do I hold the spring pins in while trying to put shift lever back on. They seem to get cocked slightly and will not pop out into the shift lever. | | | | | Joined: Jun 2012 Posts: 142 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 142 | | | | | | Joined: Mar 2010 Posts: 10,275 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,275 | Great news! I was ready to tell you that it can't be done on purpose. They only go in from random circumstance, and cannot be duplicated in only one lifetime. I resisted because I didn't want to discourage you.
