Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
0 members (), 62 guests, and 2 robots.
Topics128,009
Posts1,055,293
Members48,419
#1256243 02/24/2018 2:36 PM
1 Offline
hello ,i have a 1939 chevy 1.5 ton . i recently put in a 350 sbc , i would like some ideas on a alternator bracket for the drivers side , pretty tight fit from the rocker arm covers and below , does not have room to adjust the tension for the belt . i have a short water pump and 2 pulleys no belt tensioner and the pulleys are V belts . have tried the lower bracket which i really tight how ever 3 of the brackets have broken . thank you for looking . 1pete1
Crusing in the Passing Lane
Usually pretty easy to replace generator with alt., just make new mount tabs on existing bracket that bolts to the block to line up belts. If you have broken existing brackets, there might be something else not correctly lined up or welded properly.
Ed
Have a look at Alan Grove Components .
http://www.alangrovecomponents.com/
Sir Searchalot
Sir Searchalot
Ed
Agree with Ed. You don't need to buy anything. You can make, modify or repair-weld the brackets you have. Not sure what is broken, what room there is. No pictures! But just find a few places to attach brackets, spacers and a bar with a slot in it. Play around with it, you will eventually see a way. Post GOOD pics if you want more help. Start by placing alternator in the place you want it in. Prop it in there, use wooden blocks, clamps or wire, then start visualizing how to mount. Does it matter what side it's on?
Post this in Big Bolts, you may get more responses.
V
VEW Offline
V Offline
I changed the valve covers on the 41 (they were a wee bit higher), which caused me to relocate the alt. bracket. After playing around with it, I got the low mount bracket from Jegs. It mounts down low on the drivers side. Think it was around $50. Like you said, there's not a lot of room to work with.
~ Victor
1957 3100 - moved on
If you want it pretty do a search for "high mount alternator bracket". If you want a sure enough strong one cut a piece of 3x3x1/4 angle about 8" long and drill a pair of holes that line up with the front and front center exhaust manifold bolt holes. Use a 7/16 fine threaded nut between the angle and the manifold as a manifold clearance spacer and tack nuts to keep in place. Weld two alternator mount ears on top of the angle (or weld/bolt a factory bracket to the angle). Our 302 Ford air compressor and our sbc V8 fork lift (no kidding) are both done this way. The 302 engine runs on 4 cylinders and pumps air on the other 4 so it shakes enough to give any bracket on it a good test.
Evan
Bills hot rod shop brackets work very well for this problem and the price is resonable
