1 members (Shade Baby),
71
Mod | | | Forums66 Topics128,159 Posts1,056,901 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2016 Posts: 1 Moderated | | Moderated Joined: Feb 2016 Posts: 1 | Hey guys new to the forum, Larry helped me out in swapping a 4.10 3rd member to a 5.14. I also have a 4.57 3rd member. Not sure if thats something any of you guys need? If so I can trade and pick up a 2nd 5.14 as I would like to have a spare. Im located in So cal so you know for shipping purposes. Anything far might ruin the deal but I know business to business from So cal to Wisconsin was about 100 bucks.
Thanks, Chris | | | | | Joined: Feb 2015 Posts: 273 Shop Shark | | Shop Shark Joined: Feb 2015 Posts: 273 |
1953 3800 Dually Flatbed
| | | | | Joined: Nov 2008 Posts: 544 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 544 | In the next few months, I will have a 5.14 third member from a '49 3800 available. I'm in Central Texas. Not sure what it is worth, or if it is worth shipping. I know it is worth scrap metal at least. | | | | | Joined: Feb 2015 Posts: 273 Shop Shark | | Shop Shark Joined: Feb 2015 Posts: 273 |
| | | | | Joined: Sep 2013 Posts: 3 New Guy | | New Guy Joined: Sep 2013 Posts: 3 | As many of us are I am looking for the eaton 4.10. If anyone has one please let me know.
Thanks, Trey in Texas | | | | | Joined: Nov 1995 Posts: 5,732 24601 | | 24601 Joined: Nov 1995 Posts: 5,732 | Trey -- You know what to look for in junkyards, right? If you already have a 5.14 third member, Mrf1002u can hook you up with a swap for 4.10. If not, you have to start checking out the junkyards for a donor. See the tech tip on this upgrade for details about how to find the right center section you need. Have fun!
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: May 2006 Posts: 934 'Bolter | | 'Bolter Joined: May 2006 Posts: 934 | I have a 5.14 that is good to go if someone needs it. Another one is waiting for removal from a 1 ton to replace with a 4.10. No need to find a 4.10 for me. If your group needs one or both I can let them go. Tom | | | | | Joined: Sep 2013 Posts: 3 New Guy | | New Guy Joined: Sep 2013 Posts: 3 | Hi John, yes I do know what to look for.....been looking but to no avail. I have a couple of 4.56's in pieces, but do not have a 5.14 I want to part with at this time.
Thanks, Trey
| | | | | Joined: Jul 2014 Posts: 892 'Bolter | | 'Bolter Joined: Jul 2014 Posts: 892 | WCC5 Trey
I could use a 4.56. Do you have a matched ring and pinion and a good pinion bearing? That would save shipping compared to the whole pumpkin.
--Tom 1951 3800 1-ton"Earning its keep from the get-go"In the DITY Gallery1962 261 (w/cam, Fenton headers, 2 carbs, MSD ign.), SM420 & Brown-Lipe 6231A 3spd aux. trans, stock axles & brakes. Owned since 1971. | | | | | Joined: Sep 2013 Posts: 3 New Guy | | New Guy Joined: Sep 2013 Posts: 3 | Tommy, both of the sets I have are matched sets. Do not have the pinion bearings. PM me with your address and I will see what the shipping will be.
Thanks, Trey | | | | | Joined: Sep 2016 Posts: 1 Moderated | | Moderated Joined: Sep 2016 Posts: 1 | I am also looking to purchase a clean set of 4.10 gears. Mine are trashed so I would not be able to swap. If anyone has a set please let me know.
Kenny | | | | | Joined: Jun 2006 Posts: 36 'Bolter | | 'Bolter Joined: Jun 2006 Posts: 36 | I have a 1950 gmc 1 ton I have retired from farm use and need a better road gear now that we are going on the road. I have found an old trailer that has the 10 bolt rear end and 8 bolt wheels. It is a early 60's chevy with coil springs and leaf spring helpers that look to be factory installed. Any ideas to what the gear ratio might be? Due to the weather and it being hard to get out I would like to know if its worth pulling out. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Best methods are counting the teeth or jack up a wheel and count turns, each followed by some math. Checking it out in person is probably less effort and time and more reliable than searching and speculating on the net.
Good luck! | | | | | Joined: Feb 2015 Posts: 273 Shop Shark | | Shop Shark Joined: Feb 2015 Posts: 273 | Just popping in to say Howdy. Haven't been around a while. Glad to see this thread is still alive. Still busy with non-truck projects.
Larry W.
| | | | | Joined: Jan 2011 Posts: 70 'Bolter | | 'Bolter Joined: Jan 2011 Posts: 70 | Is 5.13:1 the only ratio the early ones had? I have been thinking that my 51 gmc 1 ton sports 5.38s. I have found a chunk from a late 60s pickup with 4.11s so I'm fine there, just curious if the 5.38 is a possibility. Thanks
1951 GMC 250 Open Express 1968 C10 Suburban 1971 C20 Pickup
My Dad told me "Son, never hit a man in anger- unless you're certain you can get away with it"
| | | | | Joined: Feb 2017 Posts: 1 New Guy | | New Guy Joined: Feb 2017 Posts: 1 | If this is still an active topic I most certainly have a set of 5.14s I'd love to swap for 4.10s
1954 Chevy 3800
| | | | | Joined: Jan 2013 Posts: 1,084 'Bolter | | 'Bolter Joined: Jan 2013 Posts: 1,084 | Larry, ready, willing and able to do a swap. PM me on particulars and we'll get it done. Many thanks.
Allen Yeah, well, that's just like, you know , your opinion, man - The Dude
1948 Chevy 3600 - goal Original restoration, Current Stage 1 - Disassembly and getting body in primer 1954 GMC 3100 goal Hot Rod, Current Stage 1 - Get body in primer 1931 Ford Model A 5 window Coupe - Old Skool Hot Rod 1945 Ford 2N Tractor - Runs great 1964 Ford 2000 Tractor - Use it every week 1974 Stingray Corvette
| | | | | Joined: May 2017 Posts: 20 Wrench Fetcher | | Wrench Fetcher Joined: May 2017 Posts: 20 | I have found 4:57's I currently have 5:14's in 1 Ton Dually ..
I Feel like 55 Mph better to get to shows with , so 4:10 might be a better Fit . .
Full Pumpkin Swap Out , Yeah . . | | | | | Joined: Feb 2018 Posts: 2 New Guy | | New Guy Joined: Feb 2018 Posts: 2 | So I have a 4.57 center section and a 4.10 center. Both open and in good shape. I also have an older style housing with slip on drums. All I’m looking for is a 5.13 center, preferably with a load bolt and in in good shape. | | | | | Joined: Aug 2011 Posts: 228 'Bolter | | 'Bolter Joined: Aug 2011 Posts: 228 | I switched my 1 ton from 5:14 to 4:10 and have the typical 4 speed. It works great around town, but has a hard time an any grade or hill pulling the hill in 4th. FYI
| | | | | Joined: Jul 2014 Posts: 1,291 Moderator for Tons o' Fun , Co-Moderator Driveline Forum | | Moderator for Tons o' Fun , Co-Moderator Driveline Forum Joined: Jul 2014 Posts: 1,291 | I switched my 1 ton from 5:14 to 4:10 and have the typical 4 speed. It works great around town, but has a hard time an any grade or hill pulling the hill in 4th. FYI I've been following this 4:10 swap thread and others that are similar, this is the first time I've read about the 4:10 and the issue of pulling hills in fourth gear. Appreciate the information as I've been contemplating the swap. Maybe some other Bolters will share their experience?
Ron - - Dusty53 1954 Chevy 3604In the Gallery Forum "You can't dance with the Devil and then wonder why you're still in Hell." "They will forget what you've said, and they will forget what you have done but they will never forget the way you made them feel." | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Sure, it won't pull as hard in 4th on a hill with 4.10 as it will with 5.14, that's expected. In my experience it still does just fine, I once passed a semi truck headed up a good hill on I-64, 4th gear, probably 55-65 MPH. That was flat out and didn't need to down shift.
Other steeper hills on local roads you'll down shift, but not always, and I don't see that as an issue.
There will always be hills you have to down shift on, depending on how steep, long, and how fast you can or can't go.
I say go for the swap and don't look back.
If you drive along in high gear and absentmindedly press in the clutch and reach for one more higher gear... It means you're not geared to fast. I still do this with 4.10 axle gears sometimes.. but not all the time like with 5.14. | | | | | Joined: Jul 2014 Posts: 1,291 Moderator for Tons o' Fun , Co-Moderator Driveline Forum | | Moderator for Tons o' Fun , Co-Moderator Driveline Forum Joined: Jul 2014 Posts: 1,291 | Hey, that's a good point.....searching for that next gear. Thanks Grigg, I needed the reminder.
Ron - - Dusty53 1954 Chevy 3604In the Gallery Forum "You can't dance with the Devil and then wonder why you're still in Hell." "They will forget what you've said, and they will forget what you have done but they will never forget the way you made them feel." | | | | | Joined: Nov 1995 Posts: 5,732 24601 | | 24601 Joined: Nov 1995 Posts: 5,732 | Appreciate the information as I've been contemplating the swap. Maybe some other Bolters will share their experience? Dusty -- For awhile, I ran the 216/4.10/4-speed SM420/17-inch wheel combo on my 3804. My truck could maintain 70-ish on a flat just fine (but you could tell that was all there was  ) but as soon as I hit a headwind (or even much of a breeze, let alone wind) or any kind of a hill, it went to 55. A real hill meant dropping a gear. or two ... Not really a show stopper, just more of a slight annoyance at times. And in the back of my mind, I was always worried about what running at the upper right corner of the "Horsepower/thrust Curve" was doing to my valiant splasher 216... Then I switched to a 261 and ... well, I no longer have these issues  And the still-good 216 is sleeping peacefully in the corner... for now ... Just my data point FWIW. John
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: Oct 2015 Posts: 406 'Bolter | | 'Bolter Joined: Oct 2015 Posts: 406 | After messing around with rear ends I found the switching to an overdrive transmission was the answer. I can actually up shift while climbing a grade,and even when I climb a serious grade and have to down shift the gears are closer together so not much speed is lost. I have a 4.57 rear with a t 5 and 5800 lb 1 ton. and the original 235. Its by no means a power house, but I can keep up with traffic.
good planning is no substitute for dumb luck
| | | | | Joined: Jul 2014 Posts: 1,291 Moderator for Tons o' Fun , Co-Moderator Driveline Forum | | Moderator for Tons o' Fun , Co-Moderator Driveline Forum Joined: Jul 2014 Posts: 1,291 | Thanks John and Panel Fan - you know, I think I'll eventually get the 4.10 put in and just see how it goes. Right now I've got so much left to do to get mine back on the road that I need to stop the future planning and get back to work on the truck. I appreciate you guys sharing your experiences.
Ron - - Dusty53 1954 Chevy 3604In the Gallery Forum "You can't dance with the Devil and then wonder why you're still in Hell." "They will forget what you've said, and they will forget what you have done but they will never forget the way you made them feel." | | | | | Joined: May 2016 Posts: 56 Wrench Fetcher | | Wrench Fetcher Joined: May 2016 Posts: 56 | I'd trade a 5:14 for a 4:10 . Live in elmdale ks. 66850
I just finished a 1946 chevy pickup street rod now on a 1950 chevy 3100 . also a GMC 220 with duals and a 1948 chevy 2 ton | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | This is not the Swap Meet.
Either contact Ronnie via email or Private Message, or, place a part for sale ad in the Swap Meet.
If you are trying to Swap your 4.10 for a 5.14, you should get a few "takers/swappers". | | | | | Joined: Nov 1995 Posts: 5,732 24601 | | 24601 Joined: Nov 1995 Posts: 5,732 | Or contact Larry (The OP for this thread) as he was the guy who set up the pumpkin trades for a lot of us.
