| | | Forums66 Topics128,113 Posts1,056,279 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2005 Posts: 123 Shop Shark | | Shop Shark Joined: Nov 2005 Posts: 123 | its been awhile since I did my front wheels. I changed the front to disc brakes. But; I needed to store the frame outside for a couple years. Now that I have the motor close to done I want to finish up the frame work. My brand new font disc brakes and rotors look 20 years old. They are sooooo rusted. Any way to clean them up or is it money lost and start over?? | | | | | Joined: Feb 2004 Posts: 29,805 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,805 | Use a ScotchBrite Roloc disc in a drill motor to polish the rust away. The 3" size works best for brake rotors. There are plenty of them on Ebay. Jerry
| | | | | Joined: Mar 2010 Posts: 10,280 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,280 | Spray on some brake cleaner or gun scrubber and scrub with a scotchbrite pad. You will then be able to see if you have pitting. Driving the truck will clean them up better than anything else if you find that they aren't pitted.
| | | | | Joined: Oct 2005 Posts: 4,252 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,252 | You can always have them turned, too. | | | | | Joined: Feb 2004 Posts: 29,805 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,805 | The rotors sold these days might- - - -if you're lucky- - - -be able to be machined once, without getting below the "discard" thickness cast or stamped on them. A slightly pitted rotor won't seriously reduce braking ability. A too-thin one will heat up and be very inefficient. Jerry
