2 members (Hotrod Lincoln, klhansen), 119 guests, and 2 robots.
Topics128,127
Posts1,056,357
Members48,441
#1255758 02/21/2018 1:41 AM
its been awhile since I did my front wheels. I changed the front to disc brakes. But; I needed to store the frame outside for a couple years. Now that I have the motor close to done I want to finish up the frame work. My brand new font disc brakes and rotors look 20 years old. They are sooooo rusted. Any way to clean them up or is it money lost and start over??
H Online: Content
Use a ScotchBrite Roloc disc in a drill motor to polish the rust away. The 3" size works best for brake rotors. There are plenty of them on Ebay.
Spray on some brake cleaner or gun scrubber and scrub with a scotchbrite pad. You will then be able to see if you have pitting. Driving the truck will clean them up better than anything else if you find that they aren't pitted.
You can always have them turned, too.
H Online: Content
The rotors sold these days might- - - -if you're lucky- - - -be able to be machined once, without getting below the "discard" thickness cast or stamped on them. A slightly pitted rotor won't seriously reduce braking ability. A too-thin one will heat up and be very inefficient.
