8 members (baldeagle, Sjm, SmalltownTRKGuy, Hotrod Lincoln, walter74, cmayna, Woogeroo, 1 invisible),
358
7
Mod | | | Forums66 Topics128,165 Posts1,057,089 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2017 Posts: 62 'Bolter | | 'Bolter Joined: Jan 2017 Posts: 62 | Hello, I'm looking into replacing the knee action shocks on my 49 with tubulars. I've found lots of info for half tons, but not 3/4's. Anyone have any insight? | | | | | Joined: Jan 2017 Posts: 62 'Bolter | | 'Bolter Joined: Jan 2017 Posts: 62 | Still searching for a solution. Should I just be searching junk yards for parts from a unit that had tubular shocks? Or is there a company that makes a conversion? Haven't found any info from people that have done it in the past. | | | | | Joined: Aug 2003 Posts: 106 Shop Shark | | Shop Shark Joined: Aug 2003 Posts: 106 | Have you compared the 1/2 ton mounts to the 3/4 ton mounts? I've found a lot of times people/businesses list stuff only for the 1/2 ton because they don't know what other models the parts will fit.
"I always win." Working mainly alone I do not let my trucks win a war. Maybe a battle here and there but never the war.
Robert 55.1 GMC 450 COE 51ish GMC Suburban | | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | Front shocks & mounts for 1/2 and 3/4 should be the same. The lower mounting tab on the axle wil need to be changed out to the angled one. The holes will need opened up for the 3/4 ton u bolts. | | | | | Joined: Jan 2017 Posts: 62 'Bolter | | 'Bolter Joined: Jan 2017 Posts: 62 | http://www.oldchevytrucks.com/cart/product.asp?prodid=HP590&i=9995|||||
Did a little more digging tonight and that ^ Is what I came up with. Also heard that front and rear upper mount brackets are the same. Can anyone confirm that?
Might have to copy and paste the link
| | | | | Joined: May 2015 Posts: 11,156 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,156 | All the catalog info I've looked at shows upper shock brackets for 50 and later 1/2 tons being the same front and back. I needed to replace one of mine that had apparently broken and been replaced by a cobbled up welded version. LMC shows the same PN for 1/2 ton and 3/4 ton front and rear upper brackets.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | |
