7 members (UtahYork, k2handyman, TUTS 59, Otto Skorzeny, 55shaker, TooMany2count, 1 invisible), 68 guests, and 3 robots.
Topics128,031
Posts1,055,433
Members48,422
#1255577 02/19/2018 7:38 PM
In "Large Bold Print"
Prior to running in the main wire harness, installing light switch and wires, key and wires, Heater and control valve, steering shaft support bracket, cowl louver support and lever, defrosters vents and hose, etc., etc., etc.
Install your inner fire wall cover first https://www.classicparts.com/1947-53-Inner-Firewall-Cover/productinfo/42-011/
It was difficult to say the least to previously install everything, then to have to remove it all in order to install the cover.
Actually a great learning experience, but it sure seems at times I'm always taking 2 steps forward only to discover that I just created a short multi-step journey backwards.
Discouraged, Yes! But I'm not going to let it beat me up. I'll just have a couple early beverages and tackle it all again on another day.
Jeff-Still learning!
Jeler #1255579 02/19/2018 7:40 PM
If it makes you feel better, Jeff: "been there; and, done that" (twice - 12 years apart) dang
Jeler #1255580 02/19/2018 7:49 PM
Jeff, don't feel bad. When I was putting my truck together I used the old saying. "If you don't do it three times, it's not done right. thumbs_up
George
Jeler #1255587 02/19/2018 9:03 PM
Tim & George
That makes me feel so much better, Thank Goodness I'm Cheap labor!
Jeff
Jeler #1255619 02/20/2018 12:51 AM
Jeff, my man, while it may seem to some that brutal honesty is admirable, in the Man Card Test Application Manual (MCTAM) Section 1, Paragraph C, there is a reference to the contrary.
It states, "If there were no witnesses, it never happened."
Be advised, the Man Card Board periodically monitors sites like this one for accreditation purposes.
An acceptable work-around would be for you to make reference to a fictitious third party who made said faux pas. Or you could actually call out a real person who has it coming to them for prior malfeasance upon you.
Carl
Jeler #1255637 02/20/2018 2:17 AM
Lit'l Bro's favorite saying, "If it's worth doing, it's worth doing 2 or 3 times".
RonR
1970 340 Duster
1964 CJ5
Jeler #1255638 02/20/2018 2:24 AM
"If you don't have time to do it right- - - - - -where are you going to find the time to do it over?"
"Measure twice- - - - -cut once!"
Jeler #1255640 02/20/2018 2:39 AM
How about, "If it's still too short, trim some more off"
Or "Beat to fit, Paint to match"
Or "If it won't fit, get a bigger hammer"
I'm pretty cheap labor too. But if I had to pay me, I'd be broke.
Jeler #1255812 02/21/2018 4:42 AM
If it ain't broke, keep fixing it till it is!
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
