| | | Forums66 Topics128,180 Posts1,057,158 Members48,464 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2001 Posts: 1,907 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,907 | Pardon my French. I took my '48 out for a drive with a small camera mounted on the seat frame. The road was what we call a "broken ice" floor. Rough as a dirt road with washboard. The video is linked below. I can hear the squawk of my clutch pedal and the squeak of wiper blades plus various rattles but what in the world is the sound like an old rattling sewing machine about 3/4 through the video? When I'm driving, I don't hear that. It seems like the cheap microphone on the camera picks up something I don't hear. Is that lifter sound? Any audio engineers out there? Can a cheap microphone pick up sounds outside my audio range and play them back in my range? One Minute of Driving Video. 12MB. 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
| | | | | Joined: Sep 2017 Posts: 135 Shop Shark | | Shop Shark Joined: Sep 2017 Posts: 135 | Kind of Sounds like a throw out bearing dinging to me from the video. wouldn't really know without being there. My 53 does that a little, but its not making self destruction noises yet so I just leave it. On edit, I did hear what I thought was a vibrating piece of metal probably close to the camera. Seat spring?
| | | | | Joined: Mar 2010 Posts: 10,307 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,307 | I bet it is something like what LeeP mentioned about the seat spring. It sounds to me like the noise is emanating from very close to the camera. It might be your fillings coming loose.
| | | | | Joined: Apr 2010 Posts: 245 'Bolter | | 'Bolter Joined: Apr 2010 Posts: 245 | Gotta love those electric wipers ! | | | | | Joined: Dec 2008 Posts: 901 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 901 | Gotta love the defroster too!!!
Brian 1955.2 3100 Truck The older I get the more dangerous I am!!!!! | | | | | Joined: Dec 2014 Posts: 678 'Bolter | | 'Bolter Joined: Dec 2014 Posts: 678 | The coolest video ever!
And if you can't personally hear the noise, I woiuldn't worry about it. Probably something the camera audio is distorting.
The good thing about noises is, they either spontaneously stop, or get so bad they're easy to locate.
1951 Chevy Panel Truck
| | | | | Joined: Sep 2016 Posts: 31 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2016 Posts: 31 | Hi, I tried once a video and got lots of strange noises from ... inside the camera and the gorilla pod which I used to fix the camera to the bench. Creaking and rattling (I used an old compact camera for obvious reasons) were as loud as any other sound inside the cab. Had the camera falling down a few times when the gorilla lost its grab, so I won't try it with my better camera. Helmut | | |
