| | | Forums66 Topics128,079 Posts1,056,301 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2017 Posts: 93 Shop Shark | | Shop Shark Joined: Apr 2017 Posts: 93 | Hello Bolters I live in Lakewood, a foothills suburb of Denver.
I have owned these trucks - 1959 Chevy 1/2 ton pickup 1956 GMC 3/4 Dubl-Duti Step Van Delivery 1954 Chevy 1 ton long bed pickup
And currently own these guys - 1946 Chevy 1.5 ton truck 1950 Chevy 2 ton cabover
-Scott Mourer | | | | | Joined: Dec 2002 Posts: 3,442 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,442 | welcome to our quiet corner of the 'Bolt.
| | | | | Joined: Apr 2017 Posts: 93 Shop Shark | | Shop Shark Joined: Apr 2017 Posts: 93 | | | | | | Joined: Sep 2016 Posts: 18 New Guy | | New Guy Joined: Sep 2016 Posts: 18 | I'm in Cheyenne, WY and I need a good mechanic to help stop a major squeak in the engine compartment of my 1953. I can trailer to wherever it needs to go. I cant seem to find where it is coming from or what to do to fix it. Help!
thx: Kldob
| | | | | Joined: Dec 2002 Posts: 3,442 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,442 | Is the squeak constant? high pitched? does it vary with RPM?
Are any of the pulleys loose? can you wiggle any of them when the engine is OFF!!
I would use a belt conditioner to rule out the belt.
If you have a long screw driver, you can carefully place the tip of the screwdriver on the generator/alternator, valve cover ect. put your ear on the handle end and listen. (be careful around moving parts)
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Dec 2002 Posts: 3,442 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,442 | KLdob, did you get this figured out?
| | | | | Joined: Sep 2016 Posts: 18 New Guy | | New Guy Joined: Sep 2016 Posts: 18 | A while back I posted about a squeak in the engine that increased with rpms. I found it! it turns out that the person that replaced the okie bearing dented the flywheel inspection into the flywheel. I would have never guessed it. It sounded like a dry bearing. anyway it is fixed now.
Keith | | |
