8 members (tclederman, Hotrod Lincoln, ChevyBlue, moparguy, mk72, farmallb, Opelika Tom, Otto Skorzeny), 179 guests, and 1 robot.
Topics128,089
Posts1,055,988
Members48,430
#1254789 02/13/2018 1:26 AM
I have pulled the straight 6 and have put a 327 in my 1955 second series truck. Where the old throttle linkage came thru the firewall it now comes out into the valve cover. Is there a linkage kit that can be purchased to solve this issue? Any suggestions or pointers would be greatly appreciated. Thanks
3B Offline
Hy Blue 55, welcome, Jim Carter Classic Truck Parts has their part number HP142 which is what you need, I won't quote a price as my catalog is an old one, hope that helps.
LoKar makes a cable actuated one that I have used on two projects.
Lots of latitude on location and uses a simple bell crank at the firewall side
of the gas pedal.
Never an issue with it.
Speedway has the same spoon type pedal for 30 bucks vs 60 for the Lokar name. Cable is the best way to go as it gives great leeway in routing and mounting.
Evan
This is the stock V8 linkage...
http://www.classicpartsusa.com/prod...qoWtS9IQjgDJTzxMyMjXzpElUDhoC7TYQAvD_BwE
Available from many sources.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
3B #1255493 02/19/2018 1:01 AM
Thanks for the info. I looked at the Jim Carter website and it looks like the linkage is on back order. I will still order one and hopefully I will get it before to long. Thanks
Thanks for the information. I appreciate your help.
