7 members (klhansen, Hawkman, mason86, mick53, festerhairball, UtahYork, 2-Ton),
100
Mod | | | Forums66 Topics128,069 Posts1,055,886 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2007 Posts: 6 New Guy | | New Guy Joined: Apr 2007 Posts: 6 | I have pulled the straight 6 and have put a 327 in my 1955 second series truck. Where the old throttle linkage came thru the firewall it now comes out into the valve cover. Is there a linkage kit that can be purchased to solve this issue? Any suggestions or pointers would be greatly appreciated. Thanks | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Blue 55, welcome, Jim Carter Classic Truck Parts has their part number HP142 which is what you need, I won't quote a price as my catalog is an old one, hope that helps. | | | | | Joined: Jul 2007 Posts: 328 'Bolter | | 'Bolter Joined: Jul 2007 Posts: 328 | LoKar makes a cable actuated one that I have used on two projects. Lots of latitude on location and uses a simple bell crank at the firewall side of the gas pedal. Never an issue with it.
| | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | Speedway has the same spoon type pedal for 30 bucks vs 60 for the Lokar name. Cable is the best way to go as it gives great leeway in routing and mounting.
Evan
| | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | | | | | | Joined: Apr 2007 Posts: 6 New Guy | | New Guy Joined: Apr 2007 Posts: 6 | Thanks for the info. I looked at the Jim Carter website and it looks like the linkage is on back order. I will still order one and hopefully I will get it before to long. Thanks | | | | | Joined: Apr 2007 Posts: 6 New Guy | | New Guy Joined: Apr 2007 Posts: 6 | Thanks for the information. I appreciate your help. | | |
