1 members (delky),
258
Mod | | | Forums66 Topics128,089 Posts1,056,141 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2005 Posts: 946 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 946 | Can anyone recommend a good epoxy primer to go on bare metal? Thanks. Michael | | | | | Joined: Jul 2004 Posts: 427 Shop Shark | | Shop Shark Joined: Jul 2004 Posts: 427 | mar-hyde is the least expensive and works well. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | The safest answer is to use an epoxy primer that is made by the same manufacturer that makes the surfacer, and/or sealer, and/or top coats that you plan to use. | | | | | Joined: Nov 2006 Posts: 84 'Bolter | | 'Bolter Joined: Nov 2006 Posts: 84 | I have been using PPG's DP epoxy primer with excellent results. | | | | | Joined: Oct 2005 Posts: 4,252 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,252 | Originally posted by Treyz: I have been using PPG's DP epoxy primer with excellent results. I second that!! Can be used over almost anything and under almost anything!!! | | | | | Joined: Aug 2005 Posts: 442 'Bolter | | 'Bolter Joined: Aug 2005 Posts: 442 | Using PPG too, sprays on nice,and takes paint very well. feel comfortable with it, may cost a little more, but after all the hours of work on the metal prep, well worth it I think
Mike | | | | | Joined: Oct 2006 Posts: 339 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 339 | PPG or Duponts URO prime, either is great material, but as Tim said, You are better off to stay within a system...mixing systems is asking for problems...Bill B | | | | | Joined: Feb 2006 Posts: 428 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 428 | For what it is worth, my buddy at the paint store recomended Omni Au epoxy primer. He knows that I have never painted any thing but a house. (not even that now that I have siding) I purchased a cheap spray gun from Harbor Freight. I put two thin coats of primer on a replacement door, and I am pleased with the results. | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Southern Polyurathanes Inc, (SPI) has a good one, compatible to almost anything, nice people, good prices, shared shipping and a website forum. SPI users forum, for all paint related questions and other topics.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Aug 2005 Posts: 442 'Bolter | | 'Bolter Joined: Aug 2005 Posts: 442 | Used the Omni AU for the interior ( seat frame so far and window trim) laid down nice, even coat and nice sheen.. this was the first time I have painted anything with an HVLP gun, other than old license plates... for the price, highly recommend it.. the primer lays down very nice!!
Mike | | | | | Joined: Jul 2005 Posts: 946 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 946 | Thanks for all the suggestions. A couple questions 1. If I use PPG or SPI epoxy primers, what would be a bulletproof topcoat from these companies? I am using this on my axles, frame and other suspension parts. 2. On some of the smaller parts I used a rattle can of 2K Urethane Primer to keep the part from rusting. What would be a good topcoat for this type of primer? Or... 3. I know I will get slapped for asking this, but can I spray epoxy primer over 2K Primer? I would scuff the metal until the high spots were bare metal leaving some of the 2K in the low areas.
Thanks. Michael | | | | | Joined: Apr 2007 Posts: 6 New Guy | | New Guy Joined: Apr 2007 Posts: 6 | The 2k doesn't form the bond that an epoxy would with the metal. I have used the ppg dp alot and i will probably go over it with por-15 for the stuff that i'm worried about gettin chipped | | | | | Joined: Jul 2005 Posts: 169 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2005 Posts: 169 | SPI Their epoxy flat out makes PPG's dplf look stupid. Any single stage urethane would go right over the epoxy for a nice "bulletproof" finish. PPG's would be DCC Dont remember the SPI single stage. And yes epoxy can go over 2K urethane primer, but on bare metal nothing NOTHING comes close to epoxy. | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | You shouldn't put POR-15 over anything but rusty metal. It won't stick to primer.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | jomichael,
What brand and product number/code did you use for:
"2. On some of the smaller parts I used a rattle can of 2K Urethane Primer to keep the part from rusting."
This would be quite handy for small jobs. It might cause me to break the "rule" of staying within the same paint system.
Thanks, Tim | | | | | Joined: Jul 2005 Posts: 946 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 946 | tclederman, The rattle can is from Transtar Autobody Technologies, Inc., item # 4613. I bought it at our local body paint supply store. They said it can be used with the Dupont Nason 2K Primer that I use as well. Below is a link to their web site. I don't know how well it will work since I have not sprayed anything over it yet, but when I sprayed Eastwood's Chassis Black Primer on bare metal it remained tacky and wiped off easily with PRE. So I sprayed this stuff on and it was dry and solid within minutes. Wear a good mask though and let me know how it works out. http://www.tat-co.com/product.asp?ID=222 Michael | | | | | Joined: Jul 2005 Posts: 946 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 946 | By the way, it looks like you can't order from their web site. I just tried and I guess a rep will call me asking me what body shop I work for! Michael | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | Originally posted by jomichael: By the way, it looks like you can't order from their web site. I just tried and I guess a rep will call me asking me what body shop I work for! Michael Jomichael's Paint & Body of course! | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | NO such thing as 2K rattle can anything. 2K is 2 part. Product and catalyst. Transtar calls it 2 in 1? 2K does not become a coating until mixed together. They can not be mixed and stored in aerosol cans.(rattle can).I am not trying to be a smarta$$. But you might as well know if you are going to throw the word 2k around, what it means. Don't forget I mentioned above that SPI has a users forum which has all the answers to your "can I use xxx over xxx"?. yo
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Jul 2005 Posts: 946 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 946 | bartamos, I do understand what 2k means, and I said the same thing to the auto body supply shop. They said that it works exactly the same as the 2k Urethane that I have been using. Maybe they have been sniffing too many fumes, stinks in there.
So what shall I call it, 2 in 1 Primer like it says on the can?
Jomichael's Paint & Body | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | The TAT website says 2-in-1 primer but does not say what it is.
They also say "They are compatible with virtually all automotive paints."
I asked the question (above) because having a 2-K spray can seems impossible.
Considering the cost of quality exterior paint, and the time and effort taken to prepare the surfaces for painting, I'll keep using small batches of DP primer from PPG as long as I am using PPG DCC as a top coat.
TAT's Technical Data Sheets have no information about the composition if the primer.
TAT's MSDS sheet indicates that it is solvent-based product (not a 2-K product). | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | If it's enamel, call it Rustoleum in a different can. If it rattles, it's rattle can. Also. I don't think it's Urethane. Why do you think it is Urethane? I don't see that on the web site. We all need to go to WATER BASED PAINT, it will be the only way to go soon. No EPA or health issues. No expensive breathing apparatus required. Do it at home! No neighbor complaints! New car Mfg are using it now. The only Co. I know of is Auto-Air Colors. Goes over any primer, I think. Just two things to learn/do. It goes on spotty and first coat not meant to cover, so we have to get used to that process. Secondly, it should be heat cured with lamps. Portable lamps OK. This is the way to go. Prices are very very reasonable and Hot Rodders are catching on. You will see many articles soon.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Jul 2005 Posts: 169 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2005 Posts: 169 | I believe its SEM that now offers a TRUE 2K epoxy and urethane primer in spray cans. It was debuted at last years SEMA show...Eric | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Here is SEM\'s catalog I could not find an aerosol (spray-can) 2K primer. Does anyone have a link to a 2-K aerosol-can primer? Here is one example. Once the can is shaken, it is good for about 8 hours. There might be a manufacturer that has a nozzle with a dual feed - the two parts mix in the nozzle. Does anyone have a link to a product like this? | | | | | Joined: Nov 2006 Posts: 84 'Bolter | | 'Bolter Joined: Nov 2006 Posts: 84 | as to sevt_chevelle post on PPG's DP primer being stupid please disreguard. I have been restoring and painting cars for 20 years. I have yet to find a primer available to the general public that bonds better than the DP epoxy primer including Duponts self etching primer 615-616. I have yet to check into the SPI epoxy primer but I will. I will post later to let you know what I find as far as bond, compatability ect... and how it stacks up agianst the DP primer. Who know it may be better but for the time being DP is excellent primer. | | | | | Joined: Jul 2005 Posts: 946 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 946 | "If it's enamel, call it Rustoleum in a different can. If it rattles, it's rattle can. Also. I don't think it's Urethane. Why do you think it is Urethane?"
Since I am not a chemist and still learning about primers, I asked the so called "pros" at our local auto body shop if there was a can of primer that I could use on small parts, under the 2k Urethane that I use for larger panels, and they handed me the Transtar. I asked what is the difference? They said nothing, its a 2 in 1 Urethane primer. Go figure, can't trust anyone in these small towns to give you professional advise.
I'm glad I asked this question before I went too far! I will try an Epoxy Primer. | | | | | Joined: Jul 2005 Posts: 169 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2005 Posts: 169 | Ill have to some looking throu my files, but it was a big name company that released the 2K spray bombs.
As for the DPLF statement, you have your opinion I have mine. But when you can take lacquer thinner to weeks/months old dplf and wipe it clean off metal, how good of a primer is that? | | | | | Joined: Jul 2005 Posts: 946 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 946 | sevt_chevelle, That's interesting, I was able to wipe off the Eastwoods Chassis Primer with their PRE product days after application. Then I sprayed the Transtar primer (note I didn't call it 2 in 1 or 2k!) on the bare metal and it would not wipe off even 10 minutes later. What gives? Are some primers more finicky than others? Probably better for a new thread. | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Small parts: SPI epoxy primer and a Preval sprayer (Harbor Freight, cheap). that's what I did. Just google Preval or search threads.
