1 members (Hotrod Lincoln),
57
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,094 Posts1,056,066 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2006 Posts: 649 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 649 | I have a 53 235 engine with the early valve cover. The head has the 4 holes for the later valve cover. The early cover leaks real bad, and I'm hoping the newer style will seal better. So I need to know how to get the two studs out, and install two bolts. I was thinking I could lock up a couple of nuts on the studs and back them out? | | | | | Joined: Aug 2004 Posts: 1,418 ODSS Lawman | | ODSS Lawman Joined: Aug 2004 Posts: 1,418 | The two nut trick is exactly how to remove the studs.
However before you do that remove the valve cover and place on something flat. Often they are bent causing leaks. Little bit of work with the body hammers can fix that.
SWEET Sergeant At Arms: Old Dominion Stovebolt Society BUNS?!?!?!Where we're going, we don't need no buns.....1950 GMC 450 1951 Chevy 1/2-TonThe GreenMachineIn the Stovebolt Gallery | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I have successfully used these techniques: - your suggestion: lock up a couple of nuts on the studs and back them out - vise grip - stud extractor #1 ; and, stud extractor #2 | | |
