1 members (68ironhead), 215 guests, and 3 robots.
Topics128,081
Posts1,055,955
Members48,430
#1255280 02/17/2018 1:47 AM
Y
Y Offline
I have a 53 235 engine with the early valve cover. The head has the 4 holes for the later valve cover. The early cover leaks real bad, and I'm hoping the newer style will seal better. So I need to know how to get the two studs out, and install two bolts. I was thinking I could lock up a couple of nuts on the studs and back them out?
ODSS Lawman
ODSS Lawman
The two nut trick is exactly how to remove the studs.
However before you do that remove the valve cover and place on something flat. Often they are bent causing leaks. Little bit of work with the body hammers can fix that.
SWEET
1950 GMC 450
1951 Chevy 1/2-Ton
The GreenMachine
I have successfully used these techniques:
- your suggestion: lock up a couple of nuts on the studs and back them out
- vise grip
- stud extractor #1 ; and, stud extractor #2
