Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
6 members (frogfarmer, UtahYork, TexasFarmTruck, Pre '68 Dave, Shade Baby, Dakota Bob), 176 guests, and 5 robots.
Topics128,277
Posts1,058,442
Members48,490
#1255057 02/15/2018 11:17 AM
Any recommendations on the best lubricant to improve a hard-to-pull/sticky choke cable? its the spiral wire wound type. I have Fluid Film, PB Blaster, lithium grease, WD-40, light machine oil, motor oil, grease, bicycle chain lube, powdered graphite., etc., all available like most garages. Looking for something that smooths out the operation but is less likely to attract crud. thanks
I had a similar problem and finally found some silicone spray that did the trick. Dave V
I think most everyone uses something different, I personally like garage door lubricant. (Lithium)
1961 ford f500
1953 3100 five window (https://www.facebook.com/1953-Chevrolet-5-window-1533405913413610/)
1955-2 3200 big window (https://www.facebook.com/Leep3200/)
55yrs as a mechanic and retired. (kind of)
I stay away from silicone compounds/treatments/mixtures around my trucks/garages.
It is hard to keep them from contaminating/ruining future paint jobs.
KROIL has a spray lube that contains graphite. ("Penephite") It will penetrate the spiral wound sheath around the cable and creep into areas other lubes won't.
www.kanolabs.com
thanks Gents
I recently purchased some small diameter clear vinyl tubing and encased the throttle and choke cables with it. Did take some massaging to get it on but I think it will help prevent having to clean and relubricate them over and over.
Ed
7
7 Offline
If the inner wire is rusty you can take it out and use sandpaper to help smooth it out, run the wire lengthwise through the paper and clean it well, then lube the wire before you push it back through the housing.
i will check for rust on the inner wire, thanks
Crusing in the Passing Lane
Plastic tube keeps the water out that rusts the innards and wire.
Ed
Gibbs Oil is a good choice - no silicone.
"Gibbs will replace all the other lubricant, penetrant and degreaser products you use, including white lithium grease, silicone, teflon, contact cleaner, carburetor cleaner and belt dressing … as well as any vinyl, leather and wood treatment products … and that saves you a whole lot of money!"
"Since 1969, when Paul Gibbs (a Harley-Davidson mechanic with a background in chemistry) invented Gibbs Brand, no one has ever expressed dissatisfaction and no one has ever returned a single can."
http://www.getgibbs.com/
OP here. to close out this thread, i did get some Penephite and used that. I removed the cable from its sheath to clean it up, then sprayed the Penephite in the hollow end (both sides). I did observe the Penephite creep its way to the outside of the spiral. After reassembly, it worked smooth as silk,
Motorcycle cable lube, because that's what I have on hand. Works well.
Matthew 6:33
1952 Chevy 1/2-ton 3100
Late '55 235/SM420/torque tube 3.55
Dalton Highway survivor (using original 216)
www.truckwithaheart.com
