6 members (1955 1 Series, 2-Ton, Shade Baby, 46 Texaco, dt235sd, 1 invisible), 346 guests, and 6 robots.
Topics128,162
Posts1,057,056
Members48,463
S Online: Content
Hello Bolters,
I have an opportunity to buy a needed valve cover for my 235 build. My question is does the original Chevorlet valve covers have a part number, mark something to tell? The one I am looking at buying looks barely used and the seller does not know the history on it. Any input to distinguish a "Re-Pop" VS Original?
Thank you.
The one I'm looking at is painted blue/gray color, oil fill towards the front, has the "Chevorlet" on it.
//Update: I bought it. It looks pretty well cared for compared to a lot of others I have looked at.
1950 Chevy 3100
8
8 Offline
In my experience, I have not seen a repro valve cover with the Chevrolet script on it. As far as quality, I have had two chrome repros that fit well. They rust easily, though. The repop timing covers are a different story.
-Tim
'51 Chevy 3104 w/'56 235, 848 Head, HEI Dizzy, Corvette Cam, Split Manifold and Dual Carter YF's
S Online: Content
Thank you 8trackdude. It is just really clean. Guessing bead/media blasted outside and inside and then painted.
1950 Chevy 3100
What year 235 would be original for you?
There were at least 4 different styles of 235 valve covers, from 1941-1962.
You can use the older style (pre-1954) on the newer engines, but not visa-versa.
S Online: Content
The 235 I am building is a 1958. It did not have a valve cover.
1950 Chevy 3100
Link to photos of engines and valve covers. (copy/paste link)
http://www.victorylibrary.com/graphics/235/6%2520cylinder%2520engines%2520with%2520photos.pdf
- Lonnie
- Lonnie
My '54 3104
Attached is that image by Pre '68 Dave, from the document/lecture/presentation-outline that Lonnie linked-to, above.
S Online: Content
Great! Thank you. That was going to be my next question. Why some have "vents" . Thank you All Very Much
1950 Chevy 3100
S Online: Content
Jerry,
Great info . Thank you.
1950 Chevy 3100
I would avoid any and all repops most are poor fitting thin metal. Made in ???.
1946 1/2-Ton Chevy
8
8 Offline
Actually, the valve covers I have had both fit well, and the metal is practically the same gauge as the original. The chrome plating is a bit cheap, but they fit well. And, even buying a few, it is much cheaper than having one of my originals chromed.
-Tim
8track,
Have you considered using the chrome powder coating from Eastwood? Looks pretty darn good! I did my oil pan with it!
Chris
8
8 Offline
Chris-
I haven't ever tried powder coating since I don't have an oven to bake it in. I stick to rattle cans.
-Tim
That photo presentation used to be on the Puget Sound Chevy Club website. At least a link was there to it. I am glad to learn that it was not lost as I could no longer find it with the link I had. Very helpful info.
Professional Novice
