4 members (oldieoldie, Jon G, 78buckshot, Hotrod Lincoln), 71 guests, and 3 robots.
Topics128,180
Posts1,057,153
Members48,464
Tophat here
I need some clarification
I have 1950 4400 1.5 ton
I’m redoing the suspension and separating the parts out to be cleaned and repainted
I want to replace the shackle pins along with new grease fitting and bushings
I got the old ones out of the leaf springs and frame mount on the front only, one end at a time.
Are all the shackle pin parts the same on these trucks during this year.
While looking through the parts book I see the same part # for both 1/2 & 3/4 ton so are the front and rear shackle parts the same throughout year and they just change/add more leafs to make 1-1 1/2 tons🎩
Thanks in advance for the lesson I’m about to receive
Tophat
1950 4400
1949 3100
1946 2 ton flatbed
1949 3800 panel
1952 3100 panel (newest one)
Queen Creek AZ
The front and rear axle shackles, pins, and bushings should be the same for 1 ton through 2 ton.
There are different length side plates for the front shackles available and I'm not sure which models used which, but you can reuse your old ones if needed, the pins and bushings are the same.
1 ton and larger have 2" front springs, same pins and bushings fit all.
3/4 and 1 ton have 2" rear springs, 1.5 and 2 ton have 2.5" rear springs... but they all use same rear spring hangers on the frame, shackles, and pins (spring bushings may be different length). The 2" springs use 1/2" spacer washers on the spring pins to take up the extra room.
With that understanding.. there may be different front pins and bushings. Some use nuts on the pins to attach the side plates. Some use a carriage bolt through the middle of the side plates.
Given a choice I buy the ones with nuts, even if not exactly original for my truck model, they're the better design.
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
Mine have the carriage bolt.
I’ll measure the front leafs when I get home.
So yes I can reuse my side plates but also one had started to spread not sure why,
maybe the carriage bolt loosened.
So all 50 year front pins were the same. I didn’t see a spacer on the rear so I’m assuming the rears are 2.5.
Thanks 🎩
Tophat
1950 4400
1949 3100
1946 2 ton flatbed
1949 3800 panel
Queen Creek AZ
No, the fronts are different.
1/2 and 3/4 ton have narrow front springs.
1 ton through 2 ton is what you can use for 2” springs.
---All pictures---
Ok now I need to find a set of front shackle bushings and pins
The rear end has the Clevis type mounting
Tophat
1950 4400
1949 3100
1946 2 ton flatbed
1949 3800 panel
Queen Creek AZ
Found complete set for front end at Chevy of the 40s
Great customer service 🎩
Tophat
1950 4400
1949 3100
1946 2 ton flatbed
1949 3800 panel
Queen Creek AZ
