7 members (TUTS 59, homer52, Otto Skorzeny, Youngin' Tut 59, dt235sd, 2 invisible), 122 guests, and 1 robot.
Topics128,052
Posts1,055,727
#1254761 02/12/2018 11:22 PM
Here's another firewall grommet question for all the folks that know more than I do.
I'm in the process of deciphering the wiring and instruments in my '48 1/2 ton chevy truck.
I have a grommet with 4 small holes (throttle,choke, temp?,oil?) but I seem to be missing the small oval plate that secures it
to the firewall. Are this available from any vendors that you know of?
Thank you
Jeff (slowly pulling my hair out putting this truck back together)
Jeler #1254765 02/12/2018 11:36 PM
Jeff,
I'll be interested in seeing other members' photos.
My 1954 trucks do not have those holes, and therefore no attachment plate.
A 4-hole 47-49 grommet is attached below.
And, a full set of 47-49 firewall is also attached, below (slightly different looking 4-hole grommet?).
That 4-hole grommet can be a pain to install.
Jeler #1254768 02/12/2018 11:57 PM
There is a metal cover held on by 2 screws. I haven't seen them offered by vendors. Check thefillingstation.com.
Jeler #1254769 02/13/2018 12:01 AM
Jeler #1254771 02/13/2018 12:03 AM
Does your 1952 have that plate, Carl ? (photo?)
It has way too many years for me to remember what was on my 1948 Panel.
Jeler #1254795 02/13/2018 2:28 AM
Tim and Carl
I have the grommet, but after some research I discover there is indeed a metal cover plate with two screws that secures it.
Here's a picture I found of it.
Jeff
Jeler #1254796 02/13/2018 2:33 AM
This is perhaps a better photo of the Escutcheon plate I'm looking for!
Jeff
Jeler #1254802 02/13/2018 2:51 AM
Former BMW Rider
Former BMW Rider
Jeff,
Check with Jerry at (816) 833-4414
or
Tom at (918) 542-3871
One of these guys should have what you're looking for.
Andy
His: 1947 Chevrolet 3104
Hers: 2008 American Saddlebred
"I proudly Stand for the Flag and Kneel for the Cross" Unknown
Jeler #1254823 02/13/2018 9:35 AM
Jeff,
Thanks for the photos.
"Tom & Jerry?"
Jeler #1254827 02/13/2018 12:14 PM
Andy
Thanks, I'll give these guys a call. I've never heard of either one of them,
Hopefully one of them will have the missing piece!
For some reason I thought I had it laying around the shop in a box someplace but
after a thorough search I came up empty.(yet again)
Tim, you are welcomed!
Jeff
Jeler #1254858 02/13/2018 4:15 PM
What are the measurements on the retainer, especially the depth of the dished in center part? I can press the cupped center into a piece of 18 gauge and you can trim to the correct size, shape, and screw hole spacing. If just wanting to hold grommet in place get the right size freeze plug and braze/weld ears on it for the screw holes.
Evan
Former BMW Rider
Former BMW Rider
Tim, that's definitely 'Tom & Jerry' as I remember them!
Andy
Jeler #1254957 02/14/2018 12:47 PM
Coilover
Thanks for the offer. Just spoke to Jerry in Independence, MO and he'll have an original on it's way soon!
