8 members (PAUL Berardi, Phak1, DaveV, Cheapskate1229, Otto Skorzeny, carbking, Peggy M, Wayne67vert),
138
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,111 Posts1,056,244 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2005 Posts: 40 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2005 Posts: 40 | I have a Miller wire feed welder.The helmet that came with it fits good and i like it but the lens is too weak. The flash from the welder hurts the eyes. What would you recommened for a lens as i want to get a darker one but not sure what it has in it right now. | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | 52motorhead,
I think the recommended lens is a #10 or #11. If you have the #10 you could scoot up to the next higher one. Every ones eyes have a different sensitivity to that frequency of light...yours must be more sensitive than most.
Too dark a shade and seeing the area to be welded becomes difficult. The shade number is usually etched in one corner of the filter. Take a look and get one shade darker. Make sure the pieces are gasketed and tight or light can get through and really ruin your day.
Stuart | | | | | Joined: Mar 2004 Posts: 874 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 874 | Just keep going to the next higher lens until you're comfortable. Different people have different sensitivity. The darker you go the less you'll see of the puddle. I used a #9 for a long time. Here is a lens shade guide. | | | | | Joined: Mar 2005 Posts: 267 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 267 | was the helmet that came with it an auto-darking unit? tom
I don't suffer from insanity, I enjoy every minute of it!
| | | | | Joined: Mar 2006 Posts: 483 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 483 | I'm a professional welder of Mig's in my shop and gas rig's with stick's on the trucks, I use a # 10 gold covered lens. It has a cool blue color instead of green. | | | | | Joined: Oct 2005 Posts: 40 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2005 Posts: 40 | Thanks guys, I'll look tomorrow and see what lens is in there. Atleast now i have a idea where to start. | | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | I have a question of another kind. I have one of the Miller's auto darkening helmets. It's 3 years old and I use it for TIG work. The darkening adjustment goes from I think 9 to 12. My problem is when I'm doing thin work with low currents, like 1/8 alum. or sst, I can't see well as it's to dark on the lowest setting. Is there a way to "lighten" up the lens short of some sort of replacement? Right now I have an old mask that I have around the shop with a lighter lens in it for this work but as I don't do welding every day and I hate to bob my head when starting a weld. I'll move my hands while bobing my head and end up starting the weld off seam. Thanks
| | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | I'm not aware of any auto-dark helmets that adjust below 9. I don't think there is a way to modify yours.
