3 members (TUTS 59, Hugh63c10, Phak1), 212 guests, and 3 robots.
Topics128,089
Posts1,055,988
Members48,430
#125422 04/05/2007 1:47 AM
I have a Miller wire feed welder.The helmet that came with it fits good and i like it but the lens is too weak. The flash from the welder hurts the eyes. What would you recommened for a lens as i want to get a darker one but not sure what it has in it right now.
#125423 04/05/2007 2:12 AM
52motorhead,
I think the recommended lens is a #10 or #11. If you have the #10 you could scoot up to the next higher one. Every ones eyes have a different sensitivity to that frequency of light...yours must be more sensitive than most.
Too dark a shade and seeing the area to be welded becomes difficult. The shade number is usually etched in one corner of the filter. Take a look and get one shade darker. Make sure the pieces are gasketed and tight or light can get through and really ruin your day.
Stuart
#125424 04/05/2007 2:26 AM
Just keep going to the next higher lens until you're comfortable. Different people have different sensitivity. The darker you go the less you'll see of the puddle. I used a #9 for a long time.
Here is a lens shade guide.
Steve
'49 3800
'52 3600
'57 3100
#125425 04/05/2007 2:37 AM
was the helmet that came with it an auto-darking unit?
tom
I don't suffer from insanity, I enjoy every minute of it!
#125426 04/06/2007 1:53 AM
I'm a professional welder of Mig's in my shop and gas rig's with stick's on the trucks, I use a # 10 gold covered lens. It has a cool blue color instead of green.
#125427 04/06/2007 2:15 AM
Thanks guys, I'll look tomorrow and see what lens is in there. Atleast now i have a idea where to start.
#125428 04/06/2007 3:03 AM
I have a question of another kind. I have one of the Miller's auto darkening helmets. It's 3 years old and I use it for TIG work. The darkening adjustment goes from I think 9 to 12. My problem is when I'm doing thin work with low currents, like 1/8 alum. or sst, I can't see well as it's to dark on the lowest setting. Is there a way to "lighten" up the lens short of some sort of replacement? Right now I have an old mask that I have around the shop with a lighter lens in it for this work but as I don't do welding every day and I hate to bob my head when starting a weld. I'll move my hands while bobing my head and end up starting the weld off seam. Thanks
#125429 04/06/2007 5:09 AM
I'm not aware of any auto-dark helmets that adjust below 9. I don't think there is a way to modify yours.
Paint & Body Shop moderator
