Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
4 members (Shaffer's1950, TrknGMC, Ed Atkisson, 1 invisible), 49 guests, and 2 robots.
Topics128,010
Posts1,055,299
Members48,419
#1254073 02/07/2018 6:24 PM
I'm getting ready to put a '64 327 in my 57 1/2 ton Chevy step side. I bought the front motor mounts from Jim Carter. The bottom bolt holes on the brackets that mount on the engine are oval shaped as if they are meant to be adjustable. The holes aren't clean; they look as if someone drilled two holes next to each other. I asked them about it, and they said all of their other ones look the same. The thing is I've seen old factory mounts, and I don't remember the holes being shaped like that. Any thoughts on this?
Thank you,
Larry
3B Offline
Hy LAJones48, you are correct, the factory block mounts have only two round bolt holes to bolt the mount to the engine block. The only reason I can think of for the "extra" holes is to possibly allow the mount to twist to clear some of the larger harmonic balancers available on some of the higher horsepower small block Chevys, the mount "stilts" are long enough that the "misalignment" may still be within range, hope that helps.
right, should be like this, might be as 3B sez, modification to allow adjustment
Thank you both. I guess I’ll try them since it’s been a long time since I received them.
Riding in the Passing Lane
I've used several of those & the holes were always round. They mounted just like the factory ones. I cut a little hunk out of the bracket to clear the 8 in. damper.
George
1972 Chevy c10 Cheyenne Super
Maybe the guy in China got it wrong and they double stamped them and sent them out anyway...mine had round holes. ohwell
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Yeah. It looks as though they're not correct. I wish that I had sent them back a long time ago. thanks again for the input.
Larry
Rusty Nuts
Rusty Nuts
If I use the front "Bird Leg" mounts for my SBC in my 1956 3600 and a corss member mount for the 700 R$ tranny. will that be enough for supporting the engine? … or does the engine need a rear area mount as well? Thanks
