| | | Forums66 Topics128,274 Posts1,058,432 Members48,489 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2012 Posts: 94 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 94 | Recently acquired a 235. Casting numbers of 3837004 suggest 55-57. Has the 848 head. Can't find the F920H serial number on pad. I'm guessing Sept 20th, H? A Thanks, phil
Phil
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | "Can't find the F920H serial number on pad." You can't find that code on the pad on the block; or, you can't find what that code means? Yes, 55-57 (all 56-62 235 heads were "848" heads). F920H would designate: F = Flint, Michigan Plant 9 = August September 20 = 20th H = 1957 3100-3800 standard transmission http://www.1954advance-design.com/chev-specs/1957-t-ser.pdfIf you want to more specifically determine/confirm the year of block/head. fine and post the date casting codes. http://1954advance-design.com/Web%20images/casting-code-photos/codes-ser-nums.html
Last edited by tclederman; 02/08/2018 12:47 AM. Reason: corrected finger-counting errore
| | | | | Joined: Dec 2001 Posts: 14,526 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,526 | ..........would 9 not = September?? | | | | | Joined: Oct 2012 Posts: 94 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 94 | Thanks Tim, Yes, I meant could not find what it meant. Just what I needed...
Phil
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | ..........would 9 not = September?? I was counting fingers incorrectly, Alvin. Correction has been made, above. Thanks | | |
