0 members (), 40 guests, and 2 robots.
Topics128,030
Posts1,055,428
Members48,422
Recently acquired a 235. Casting numbers of 3837004 suggest 55-57. Has the 848 head. Can't find the F920H serial number on pad.
I'm guessing Sept 20th, H? A
Thanks, phil
Phil
"Can't find the F920H serial number on pad."
You can't find that code on the pad on the block; or, you can't find what that code means?
Yes, 55-57 (all 56-62 235 heads were "848" heads).
F920H would designate:
F = Flint, Michigan Plant
9 = August September
20 = 20th
H = 1957 3100-3800 standard transmission
http://www.1954advance-design.com/chev-specs/1957-t-ser.pdf
If you want to more specifically determine/confirm the year of block/head. fine and post the date casting codes.
http://1954advance-design.com/Web%20images/casting-code-photos/codes-ser-nums.html
Last edited by tclederman; 02/08/2018 12:47 AM. Reason: corrected finger-counting errore
..........would 9 not = September??
Thanks Tim,
Yes, I meant could not find what it meant.
Just what I needed...
Phil
I was counting fingers incorrectly, Alvin. Correction has been made, above.
