1 members (TrknGMC),
31
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,010 Posts1,055,299 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2007 Posts: 226 'Bolter | | 'Bolter Joined: May 2007 Posts: 226 | I'm getting ready to put a '64 327 in my 57 1/2 ton Chevy step side. I bought the front motor mounts from Jim Carter. The bottom bolt holes on the brackets that mount on the engine are oval shaped as if they are meant to be adjustable. The holes aren't clean; they look as if someone drilled two holes next to each other. I asked them about it, and they said all of their other ones look the same. The thing is I've seen old factory mounts, and I don't remember the holes being shaped like that. Any thoughts on this?
Thank you, Larry | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy LAJones48, you are correct, the factory block mounts have only two round bolt holes to bolt the mount to the engine block. The only reason I can think of for the "extra" holes is to possibly allow the mount to twist to clear some of the larger harmonic balancers available on some of the higher horsepower small block Chevys, the mount "stilts" are long enough that the "misalignment" may still be within range, hope that helps. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | right, should be like this, might be as 3B sez, modification to allow adjustment Bill | | | | | Joined: May 2007 Posts: 226 'Bolter | | 'Bolter Joined: May 2007 Posts: 226 | Thank you both. I guess I’ll try them since it’s been a long time since I received them. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I've used several of those & the holes were always round. They mounted just like the factory ones. I cut a little hunk out of the bracket to clear the 8 in. damper. George They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Mar 2004 Posts: 6,212 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,212 | Maybe the guy in China got it wrong and they double stamped them and sent them out anyway...mine had round holes.  Mike B  | | | | | Joined: May 2007 Posts: 226 'Bolter | | 'Bolter Joined: May 2007 Posts: 226 | Yeah. It looks as though they're not correct. I wish that I had sent them back a long time ago. thanks again for the input.
Larry | | | | | Joined: Jan 2019 Posts: 53 Rusty Nuts | | Rusty Nuts Joined: Jan 2019 Posts: 53 | If I use the front "Bird Leg" mounts for my SBC in my 1956 3600 and a corss member mount for the 700 R$ tranny. will that be enough for supporting the engine? … or does the engine need a rear area mount as well? Thanks | | |
