7 members (Gray_Ghost, Rusty Heaps, Brian Moore, 55shaker, Otto Skorzeny, Hotrod Lincoln, 1 invisible),
85
Mod | | | Forums66 Topics128,028 Posts1,055,414 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2017 Posts: 76 'Bolter | | 'Bolter Joined: Aug 2017 Posts: 76 | If I fit a disc conversion kit front only to a 56 3100 do I have to upgrade the master cylinder or fit a booster as well | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | No you don't "have " to. Will need proportioning valve and original MC bore may be too small. Among other things.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Aug 2017 Posts: 76 'Bolter | | 'Bolter Joined: Aug 2017 Posts: 76 | What else would be involved? | | | | | Joined: Oct 2016 Posts: 916 'Bolter | | 'Bolter Joined: Oct 2016 Posts: 916 | I agree with Bartamos. My experience is that you can certainly try it that way, but I think that you will discover that doing it that way is a rather large step backwards in regards to the amount of pedal pressure required to get your truck to stop and it is likely that your rear drums are going to lock up fairly early in the process. Be prepared $$$ to install a boosted MC kit with a proportioning valve.
~ Dave 1950 Chevrolet 3600 3/4-ton with 261 engine & T5 Transmission | | | | | Joined: Jun 2005 Posts: 1,001 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 1,001 | When you have only drum brakes, the brake fluid returns to the reservoir when you release your brake pedal. You release pressure on your brake pedal, the brake return springs causes the shoes the retract, which cause the wheel cylinder to retract, which forces brake fluid back into the system.
With disc brakes, that does not happen. When you apply the brakes, fluid fills the calipers and pistons compress the pads. When you release your brake pedal, the fluid does not return to the reservoir. As your brake pads wear, you need more fluid to apply the same amount of pressure.
That is why on a master cylinder for a disc/drum application, the disc reservoir has a larger capacity than the drum reservoir.
I think I've go that right, but if I don't, some knowledgeable Bolter will correct me.
~ Victor 1941 3/4-Ton Pickup (in process). Read about it in the DITY Gallery1955 Grumman Kurbside "Doughboy" 235/3 on tree w/ OD 1957 3100 - moved on 1959 C4500 Short Bus "Magic Bus" - moved on 1959 G3800 1 Ton Dually "Chief" - moved on 1958 C4400 Viking "Thor" ~ moved on to fellow Bolter | | | | | Joined: Apr 2005 Posts: 2,097 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,097 | The very worst part of the drum brake system on these trucks is the stock master cylinder. I certainly would not attempt to use it with discs. I have installed a booster and upgraded MC with stock brakes on both cars and trucks before disc brakes were available and they operated much better. Do it right, use a dual diaphram booster, dual MC, and a proportioning valve and you will have great brakes. The last booster/MC unit I purchased was under $300, well worth the expense. Fred
| | | | | Joined: Dec 2015 Posts: 2,062 Big Bolt Forum Moderator | | Big Bolt Forum Moderator Joined: Dec 2015 Posts: 2,062 | as said above, buy a booster/master cyl kit as well. You can get one that goes in the stock spot and works with your stock pedal. You can get it with a remote reservoir that you can mount under the hoos where you can get to it to check and fill it. | | | | | Joined: Feb 2004 Posts: 29,748 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,748 | Drum brakes can do plenty of stopping- - - -otherwise 18 wheelers wouldn't still use them. Getting 40 tons hauled down from highway speeds repeatedly isn't an easy task. Disc brakes are really a giant leap backwards from drums as far as stopping ability goes. They use a tiny contact patch of the pad on the rotor, and extremely high clamping force to create the friction necessary to stop the vehicle. Vacuum-boosted drum brakes worked for years before discs became popular. The only advantage to discs is the fact they're less prone to "fade"- - - -where the drum or disc absorbs so much heat it loses its ability to provide braking effect. Discs cool faster than drums, due to the hollow spaces between the swept surfaces, and the long sweep after leaving the pads before the friction is applied again. Bigger diameter and/or wider drum brakes with a vacuum booster on the master cylinder would be as good as discs, maybe better, up to the point where fade begins. Jerry
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Disc may or may not be as "good" as shoes but, probably are better. Pad surface area is greater and there aren't a dozen or more springs, clips, pins, nails, adjuster wheels, wheel cylinders, bars........to screw with. Much better idea if you can afford the swap. Pretty sweet with power assist and dual MC. Rear brakes don't need disc on our trucks. As said, disc better for heat dissipation and water throw off. The big trucks are switching from drum to disc to meet a "new", mandated, shorter stopping distance requirement.
Excerpts from Dec. 15, 2005, notice of proposed rulemaking (NPRM) to improve the stopping distance performance of truck tractors, the National Highway Traffic Safety Administration (NHTSA)
Increased Use of Air Disc Brakes While already highly utilized in Europe and in select North American applications, air disc brakes are experiencing continued growth in popularity on North American highways with commercial vehicle fleets and owner-operators. Previously considered a niche technology for bus, coach, fire trucks, and other special applications, air disc brakes are becoming increasingly sought out for over-the-road applications. Bendix experienced a nearly 120 percent increase in demand for these advanced braking systems from 2009 to 2010. The company added a new assembly line in 2011 to meet increasing demand. In early 2012, Bendix Spicer Foundation Brake reached the quarter-million milestone on the brake, which it began producing in 2005. The company surpassed the 400,000-unit mark in early 2013, an increase of more than 60 percent in just one year. Industrywide, air disc brakes represent only a 10 percent market share, with drum brakes encompassing 90 percent. Their acceptance is clearly growing, however, as evidenced by the ever-increasing output at Bendix. The industry is increasingly demanding air disc brakes and the higher performance and safety they offer, as well as their reduced maintenance demands.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Nov 2012 Posts: 138 'Bolter | | 'Bolter Joined: Nov 2012 Posts: 138 | I agree with Bartamos. Disks are a huge improvement. I haven't heard of anyone "upgrading" their factory disks to drums! A BIG problem with drum breaks is getting the shoes arked to the same curvature as the drums. If the drums are turned and the new shoes don't make full contact then you'll have awful brake performance. Happily that isn't a problem with disks. Brake shops used to have the machine to grind the proper ark on the new shoes but good luck finding those machines now as they produce asbestos dust.
I disagree that running the stock master cylinder would work in a satisfactory manner. You need a m/c made for disk /drum applications. As for the need for a boosted m/c, I am running a non boosted master cylinder on my disk /drums and the pedal feel is nice.
David | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | ....................think about being SAFE. What is it worth to you and your family? | | |
