2 members (J Lucas, pauld), 123 guests, and 2 robots.
Topics128,183
Posts1,057,263
Members48,467
does it make a difference??
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
Louder and you don’t want to hold the button very long at each honk.
Agreed... a 6V horn on 12V is loud enough to scare the bejezzus out of a railroad conductor.
Crusing in the Passing Lane
Or some female(usually) fondling their device at a red light.
Ed
To take the load off the horn wiring going up the steering column, it's a good idea to install a relay to carry the current to the horn. If you want to install a 1 ohm 200 watt resistor inline with the relay, it will moderate the volume a little.
Thanks all, very helpful. Was to help on my Plymouth Owners Club.
2017 Buick Encore
See more pix
I rewired my horns when I went to 12-volt 10 years ago. I put them in series instead of the original parallel. Of course, I had to insulate the first horn in the circuit using nylon bolts and several pieces of plastic milk bottle between the mounting plate and the firewall.
It seems the 2nd horn might get an oscillating current from the 1st but it seems to work.
The horns on my truck were barely adequate. I had tried to adjust them for best operation. When I changed over to 12 volts last season the horns sounded just right. Of course I changed the relay over to a 12 volt relay.
The horns on my 38 Master are deafening just running on 6 volts. I think I would put them in series for 12 volts.
1951 1 Ton Completed
I have two 6v horns being fed with 12v of juice. OMG!! I love it.
Craig
Great idea! Thanks!
6v horn relay
A 6v horn relay was used with the standard horn from 53-55st.
A 6v horn relay was used with the optional/accessory dual horns (47-55st).
And if you search for it you can find. 12 Volt horn relay
Julian Carter
1970 Triumph GT6
1967 Triumph TR4A
1952 Chevy 3600
1948 MG-TC
Try this resistor
https://www.speedwaymotors.com/Electric-12-Volt-to-6-Volt-Reducer-for-Motors,15824.html?sku=91064103&utm_medium=CSEGoogle&utm_source=CSE&utm_campaign=CSEGOOGLE&gclid=EAIaIQobChMI0YfZiaq12QIVkVp-Ch3YIQTgEAQYAiABEgIZS_D_BwE
It's what is commonly used on 6-12v blower motors.
A good place to mount it would be next to the horn for heat dissipation.
Resistor
1954 3600 Chevy Truck
"The Fake Truck"
More pix on Photobucket
Just switched, after 14 years, to a 12 volt sys. in my 3/4 ton , 3600. I put a relay on the gas tank to drop to 6 volts, my question....what about my lights?? didn't try them because I'm a thinken they will pop! Do I need to change ALLthe lights to new 12 volters??[ and is that a real word?] Thanks again, Paul ....PS all new 12 volt wiring, ans led stop lights....6 volt head lights were sooo dim//////Thanks again, to a great bunch of guys that help us'ens with 10 thumbs!
Here is a Stovebolt.com Tech Tip on 6v to 12v conversion.
Yes, you should change all light bulbs to 12v.
