6 members (farmallb, ChevyBlue, 2-Ton, carbking, Hotrod Lincoln, tclederman), 144 guests, and 1 robot.
Topics128,089
Posts1,055,991
Members48,430
#1253755 02/04/2018 10:07 PM
I'm putting the bed of my pick up back together. I'm not using the wood planks but I have a pc. of 1/8" aluminum diamond plate to use. I'll build a 1"x1/2" tube frame to make up the difference of the wood thickness. I won't be hauling anything in the bed. I plan to build a "cargo box" to hold a gas tank and a battery box. Question is should I put the diamond plate the full length of the bed and mount the gas tank and battery to the diamond plate (build up of explosive gases?) or leave the cargo box open on the bottom and have a steel frame for a gas tank and battery?
Thanks, Dave
62401
Dave,
Well, no expert opinions, so.... you get *my* opinion, FWIW ... packaging a gas tank and a battery (lead acid, I assume?) together in a metal box pretty much sounds like an IED to me .... eeeek
I'd go with the open bottom at least. Do the gas tank and the battery *have* to live together?? Seems to me that on most production vehicles I am familiar with, the battery and the gas tank live on opposite ends of the vehicle .... Probably a reason for that ... Just sayin' smile
Regards,
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
I think your concerns and those posted by John are valid. At the very least make sure there is plenty of ventilation if you do choose to put them together.. nono
I'm not thrilled about a gas tank and a battery together but I plan on using an AGM battery in it's own sealed compartment. My other project is a 68 Corvette. That battery is in an inside compartment right in back of the drivers head!! I use an AGM battery there.
Thanks, Dave
