3 members (farmallb, DaveV, Peggy M), 47 guests, and 3 robots.
Topics128,030
Posts1,055,430
Members48,422
#1253614 02/03/2018 8:42 AM
Hi folks.Can the heater valve that controls flow through the heater be removed and bypassed .Would removal cause any problems.Thankyou
Stooby #1253625 02/03/2018 1:57 PM
Heat all the time? ohwell
Stooby #1253641 02/03/2018 4:35 PM
Ranco valve on the firewall, or ball valve at the water pump?
Stooby #1253642 02/03/2018 5:04 PM
Big Bolt Forum Moderator
I removed the one in my 58 and replaced with a valve similar to this one.
https://www.ebay.com/itm/HVAC-Heater-Control-Valve-Heater-Valve-Vacuum-UAC-HV-5952C-/222504090873
It has 4 hose fittings on it, with no vacuum, it flows water through the heater core, add vacuum, and it bypasses the heater core. Sorry, I am not at home and don't have the part # that I used with me. I can post it when I get back home but, it will be a week.
I leave it on during the winter and then put vacuum to it to bypass in the summer. I have not done anything to control it from in the cab though, I have to get out and lift the hood.
Mike
Moderated by  ndkid275, Phak1
