0 members (),
40
Mod | | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2017 Posts: 76 'Bolter | | 'Bolter Joined: Aug 2017 Posts: 76 | Hi folks.Can the heater valve that controls flow through the heater be removed and bypassed .Would removal cause any problems.Thankyou | | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | Heat all the time?
| | | | | Joined: Mar 2010 Posts: 10,271 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,271 | Ranco valve on the firewall, or ball valve at the water pump?
| | | | | Joined: Dec 2015 Posts: 2,062 Big Bolt Forum Moderator | | Big Bolt Forum Moderator Joined: Dec 2015 Posts: 2,062 | I removed the one in my 58 and replaced with a valve similar to this one. https://www.ebay.com/itm/HVAC-Heater-Control-Valve-Heater-Valve-Vacuum-UAC-HV-5952C-/222504090873It has 4 hose fittings on it, with no vacuum, it flows water through the heater core, add vacuum, and it bypasses the heater core. Sorry, I am not at home and don't have the part # that I used with me. I can post it when I get back home but, it will be a week. I leave it on during the winter and then put vacuum to it to bypass in the summer. I have not done anything to control it from in the cab though, I have to get out and lift the hood. | | |
