4 members (Steelonsteel, Hotrod Lincoln, 3800GUY, Barry Martak), 118 guests, and 2 robots.
Topics128,113
Posts1,056,613
Members48,450
#125364 04/02/2007 12:30 PM
Junior Member
Junior Member
What kind of paint did these old trucks come with off the factory floor, enamel? What kind of paint should you use when restoring a truck to original? Thanks
Advance-Design trucks' exterior paint was Dupont Dulux alkyd resin enamel. The interior paint might of been Dulux or it might have been Duco nitrocellulose lacquer.
Neither paint line is still available from Dupont.
Good substitute paint would be acrylic enamels, 2-part single stage urethane enamels, or 2-part/2-stage clear-coat/base-coat enamels.
PPG Delstar acrylic enamel is very good.
PPG Concept (DCC) acrylic urethane enamel is an excellent 2-part, single stage paint that can be polished to a beautiful finish.
if you look at chevy duty they sell the original paint colors, they are mixed to the exact colors as factory
1949 Chevy 3600 Flatbed all orginal
1964 gmc 4000
1973 gmc 6000
2005 chevy duramax 4x4
1994 chevy 1500
Trucks are GM and Tractors are Orange
"I don't measure a man's success by how high he climbs but how high he bounces when he hits bottom." - General George S. Patton
Junior Member
Junior Member
Thank you for your help. What do most people use? Does it really matter as long as the paint is shiny?
If you are going to paint this yourself, use whatever paint you can afford and feel comfortable applying. If you are going to hire somebody to paint it, use whatever paint system they are most familiar with.
The trucks were not originally very shiny or well painted, so anything from fleet paint on up looks appropriate.
Paint & Body Shop moderator
I believe that you should use modern two part urethane paint just because it is superior to any prior paint system. You can get the original colors at most paint suppliers. Even though base coat clear coat is the standard these days a lot of folks that do restoration work use a single stage urethane as they believe it looks more original then the depth of shine that you get with BC/CC. I am spraying mine with a Dupont single stage urethane and am very pleased with it.
1950 Chevrolet 3100 Deluxe Cab
Gallery Page
Webshots photos
Yes, definately use a modern paint system, and use the hardener. Your paint will last a lot longer.
