Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
4 members (TooMany2count, 60steve, Lightholder's Dad, klhansen), 140 guests, and 1 robot.
Topics128,277
Posts1,058,451
Members48,490
#1253622 02/03/2018 1:31 PM
Hi, I recently painted the interior of my 57 3100, removing the door trim on each door as they were worn. I adjusted the doors so they close as good as I could get them without the trim in place.The new set I ordered fit fine but they seem so thick that it hinders the door from closing, especially the curved front part of the door where it closes against the body. Before I start to cut the depth and thickness of the trim, I was wondering if anyone has ever had this issue? Thanks Kevin
Thanks, keep truckin!
I would think it would "wear in" after the summer heat sets in. eeeek
Like Martin said, give it some time. I had the same issue a couple years ago, I can't say exactly how long it took for the new gaskets to conform properly but it was a few months. All's good now.
As hard as it is to believe, with the new gaskets and other steps taken to quite and seal the cab, I now have to roll a window down in order to close the doors so they latch properly. Who'd have imagined.
Good Luck, Ron
RonR
1970 340 Duster
1964 CJ5
Wow, that’s something! I never thought it would seal that tightly. I’ll try to be patient but it’s not one of my strong suites, thanks everyone
Spray silicone will help a lot , Look for the dry film
!956 Gmc Napco 4x4 Factory line built .
Moderated by  ndkid275, Phak1
