0 members (),
68
Mod | | | Forums66 Topics128,274 Posts1,058,433 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2015 Posts: 33 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2015 Posts: 33 | Hi, I recently painted the interior of my 57 3100, removing the door trim on each door as they were worn. I adjusted the doors so they close as good as I could get them without the trim in place.The new set I ordered fit fine but they seem so thick that it hinders the door from closing, especially the curved front part of the door where it closes against the body. Before I start to cut the depth and thickness of the trim, I was wondering if anyone has ever had this issue? Thanks Kevin
Thanks, keep truckin!
| | | | | Joined: Apr 2005 Posts: 7,441 Bolter | | Bolter Joined: Apr 2005 Posts: 7,441 | I would think it would "wear in" after the summer heat sets in.
| | | | | Joined: Sep 2013 Posts: 1,367 'Bolter | | 'Bolter Joined: Sep 2013 Posts: 1,367 | Like Martin said, give it some time. I had the same issue a couple years ago, I can't say exactly how long it took for the new gaskets to conform properly but it was a few months. All's good now.
As hard as it is to believe, with the new gaskets and other steps taken to quite and seal the cab, I now have to roll a window down in order to close the doors so they latch properly. Who'd have imagined.
Good Luck, Ron
RonR
1951 3600 with Clark flatbed, T5, 4.10 rear 1970 340 Duster 1990 5.0 V8 Miata (1990 Mustang Gt Drivetrain) 1964 CJ5
| | | | | Joined: Feb 2015 Posts: 33 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2015 Posts: 33 | Wow, that’s something! I never thought it would seal that tightly. I’ll try to be patient but it’s not one of my strong suites, thanks everyone
| | | | | Joined: May 2017 Posts: 100 'Bolter | | 'Bolter Joined: May 2017 Posts: 100 | Spray silicone will help a lot , Look for the dry film
!956 Gmc Napco 4x4 Factory line built .
