3 members (David Bush, mk72, Bill Hanlon), 130 guests, and 4 robots.
Topics128,053
Posts1,055,777
#1253455 02/01/2018 11:01 PM
Installed a new cable and head. Odometer works fine,speedo does not work.Any ideas?
Midpiner #1253456 02/01/2018 11:02 PM
Sorry it is in a 56,3200.
Midpiner #1253461 02/02/2018 12:05 AM
What do you mean by head?
Did you happen to take the cable out of the housing and put it back in from the wrong end? There is a stop on the cable to keep it where it belongs. If it is put in wrong, the cable won't engage fully and you can have your kind of issue.
Midpiner #1253468 02/02/2018 12:33 AM
By head I mean whole new assembly(speed-o,o-dometer) never took the cable out of housing.
Midpiner #1253474 02/02/2018 1:04 AM
New/unused assembly or new/used assembly?
Either way, as you probably have guessed, something is wrong with the speedometer in the assembly.
Midpiner #1253481 02/02/2018 1:17 AM
New from classic industries.Guess I will call them tomorrow.Thanks,,i was afraid it was bad.
Midpiner #1253486 02/02/2018 2:00 AM
Is the needle dragging?
Lots more pictures
Midpiner #1253488 02/02/2018 2:35 AM
No,it is not moving.
Midpiner #1253497 02/02/2018 4:15 AM
If the odometer is racking up the miles, then everything from the transmission all the way to the head is working, so that only leaves the speedometer. I had to return two defective units until I got one in my '56 that would last more than a few hundred miles, mine had odometer issues...
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Midpiner #1253541 02/02/2018 4:47 PM
Thanks for your help,i will get on the phone shortly. Again THANKS.
Midpiner #1255602 02/19/2018 11:38 PM
Sent speedo back.Got new one works perfect.
