| | | Forums66 Topics128,035 Posts1,055,556 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2012 Posts: 142 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 142 | Installed a new cable and head. Odometer works fine,speedo does not work.Any ideas? | | | | | Joined: Jun 2012 Posts: 142 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 142 | Sorry it is in a 56,3200. | | | | | Joined: Mar 2010 Posts: 10,272 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,272 | What do you mean by head? Did you happen to take the cable out of the housing and put it back in from the wrong end? There is a stop on the cable to keep it where it belongs. If it is put in wrong, the cable won't engage fully and you can have your kind of issue.
| | | | | Joined: Jun 2012 Posts: 142 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 142 | By head I mean whole new assembly(speed-o,o-dometer) never took the cable out of housing. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | New/unused assembly or new/used assembly?
Either way, as you probably have guessed, something is wrong with the speedometer in the assembly. | | | | | Joined: Jun 2012 Posts: 142 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 142 | New from classic industries.Guess I will call them tomorrow.Thanks,,i was afraid it was bad. | | | | | Joined: Nov 2011 Posts: 1,611 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 1,611 | | | | | | Joined: Jun 2012 Posts: 142 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 142 | | | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | If the odometer is racking up the miles, then everything from the transmission all the way to the head is working, so that only leaves the speedometer. I had to return two defective units until I got one in my '56 that would last more than a few hundred miles, mine had odometer issues... Mike B  | | | | | Joined: Jun 2012 Posts: 142 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 142 | Thanks for your help,i will get on the phone shortly. Again THANKS. | | | | | Joined: Jun 2012 Posts: 142 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 142 | Sent speedo back.Got new one works perfect. | | |
