5 members (rfs56trk, WingWright, Jon G, Rusted Nut, Woodcmiami), 117 guests, and 1 robot.
Topics128,109
Posts1,056,260
Members48,439
I have been under my truck so much in the last few weeks I think I have it memorised.
All of the bushings have...well be smooshed over the 40 yrs of their life. Can these things be replaced without pulling the cab/frontend/etc?
What I am thinking is to work on one corner at a time. Loosen up the bolts, put in jack with some wood and lift up that corner. Pull out old stuff put in new stuff. Lower and re-bolt. Move on to other corner.
(This totally leaves out the fact that I ahve yet to come across one bolt that wasn't rusted solid...but ce la vie.)
Is this a possible approach? Has anyone tried this? What would I be getting into?
1965 Chevy C-30 1-Ton
"Work like you don't need the money. Love like you've never been hurt. Dance like nobody's watching."
piece a cake sable, loosen all corners first and won't take much jacking, you might be able to use a 2x4 to lever each corner up enough
If the bolts are very rusty, I have used a Sawzall to simply cut bushing/bolt & all. The kits usaully come w/new bolts etc. Your 1 ton should have the shear type mount on the rear, these will be tough as there is no replacement, but Steele rubber rebuilds them. Brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
