| | | Forums66 Topics128,113 Posts1,056,279 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2007 Posts: 172 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 172 | I have been under my truck so much in the last few weeks I think I have it memorised.
All of the bushings have...well be smooshed over the 40 yrs of their life. Can these things be replaced without pulling the cab/frontend/etc?
What I am thinking is to work on one corner at a time. Loosen up the bolts, put in jack with some wood and lift up that corner. Pull out old stuff put in new stuff. Lower and re-bolt. Move on to other corner.
(This totally leaves out the fact that I ahve yet to come across one bolt that wasn't rusted solid...but ce la vie.)
Is this a possible approach? Has anyone tried this? What would I be getting into? 1965 Chevy C-30 1-Ton "Work like you don't need the money. Love like you've never been hurt. Dance like nobody's watching." | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | piece a cake sable, loosen all corners first and won't take much jacking, you might be able to use a 2x4 to lever each corner up enough
Bill | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | If the bolts are very rusty, I have used a Sawzall to simply cut bushing/bolt & all. The kits usaully come w/new bolts etc. Your 1 ton should have the shear type mount on the rear, these will be tough as there is no replacement, but Steele rubber rebuilds them. Brian | | |
