1 members (NJC),
151
0
Mod | | | Forums66 Topics128,117 Posts1,056,296 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2005 Posts: 1,002 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 1,002 | Well, I need a shifter for the 41 that I put a 700r4 in. I've been looking around and want to check with the voices of experience before pulling the trigger on this $300 purchase. I thought a ratchet shifter would be good, given the limited space in these cabs. Any of you guys use one? Like it? Pros? Cons? Thanks for your advise.
~ Victor 1941 3/4-Ton Pickup (in process). Read about it in the DITY Gallery1955 Grumman Kurbside "Doughboy" 235/3 on tree w/ OD 1957 3100 - moved on 1959 C4500 Short Bus "Magic Bus" - moved on 1959 G3800 1 Ton Dually "Chief" - moved on 1958 C4400 Viking "Thor" ~ moved on to fellow Bolter | | | | | Joined: Feb 2004 Posts: 29,805 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,805 | "Automatic transmissions are smarter than all drivers, and most mechanics"! That's a quote from my father, who was the first man in Nashville Tennessee to work on automatics, back in the late 1940's. That's still true today. Any linkage that gets it into Drive, Reverse, and Park will get the job done- - - - -anything fancier is just something to play with. Rig up a plain old cable operated shifter from something like a Pinto, and cut the pockets out of your pants. The trans will shift just fine, and your plaything will be more fun than a stick shift! Jerry
| | | | | Joined: Jun 2005 Posts: 1,002 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 1,002 | Thanks Jerry. Your opinion is always valued!!
~ Victor 1941 3/4-Ton Pickup (in process). Read about it in the DITY Gallery1955 Grumman Kurbside "Doughboy" 235/3 on tree w/ OD 1957 3100 - moved on 1959 C4500 Short Bus "Magic Bus" - moved on 1959 G3800 1 Ton Dually "Chief" - moved on 1958 C4400 Viking "Thor" ~ moved on to fellow Bolter | | | | | Joined: Dec 2017 Posts: 24 New Guy | | New Guy Joined: Dec 2017 Posts: 24 | Your right about the limited space in the cab. That is why I went with a column shifter for my 7004R. Much more comfortable when you have three people in the cab then when you have a floor shifter. But I went with a Ididit strg.. column , so I just ordered it with column shift. Has worked out very well.
Tom 1950 3100
| | | | | Joined: Feb 2004 Posts: 29,805 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,805 | Has anybody considered a dash-mounted shifter like the mid-1950's MOPAR cars had? My aunt's 55 Dodge comes to mind. It had a slot in the dash with about 4 or 5 selector positions available. Fabricating or adapting something like that to a stovebolt shouldn't be too difficult. Jerry
| | | | | Joined: Jun 2005 Posts: 1,002 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 1,002 | Well Jerry, after your suggestion about using something from a Pinto, I got to thinking.... I've got a lever than was in my 50 Willys truck that was used the activate the snow plow motor. It's a heavy duty lever with a heavy duty cable. It would probably work. My concern it that I would inadvertently move it from D to P while travelling down the road!
~ Victor 1941 3/4-Ton Pickup (in process). Read about it in the DITY Gallery1955 Grumman Kurbside "Doughboy" 235/3 on tree w/ OD 1957 3100 - moved on 1959 C4500 Short Bus "Magic Bus" - moved on 1959 G3800 1 Ton Dually "Chief" - moved on 1958 C4400 Viking "Thor" ~ moved on to fellow Bolter | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | I have used, and prefer, the Lokar Nostalgic floor shifter. Nice piece of kit.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Feb 2004 Posts: 29,805 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,805 | I'd suggest making a guide slot that resembles a sawtooth pattern, where the shift handle has to deflect sideways a little to change positions. It's easy to fabricate from a piece of aluminum or stainless steel. If you really want to get creative, get out the stamping dies and label the positions. The old Chevy cast iron Powerglide had Reverse at the bottom of the quadrant, and no reverse lockout. (P-N-D-L-R) I've grabbed "R" a few times in a 55 passenger car when trying for "L"! That's a real attention-getter! Jerry
